-   CBR 1000F "Hurricane" (https://cbrforum.com/forum/cbr-1000f-hurricane-38/)
-   -   what type of fuel should I use? (https://cbrforum.com/forum/cbr-1000f-hurricane-38/what-type-fuel-should-i-use-40002/)
bhhacker May 23, 2007 10:47 PM
Hey there,
I was wondering what type of fuel I should use. The previous owner said she only used supreme, but im thinking that his bike being so old should be able toget along with the cheap stuff just as good and i might just be building up on carbon. Alos, if anyone hasa link to a service manual...you might want to give it before I litter this whole board with "dumb" questions :P
weekendrider May 23, 2007 11:03 PM
RE: what type of fuel should I use?
The bookhas 91 or higher, my 88 pings on low octane so i always run high octane
WhiteHawk May 23, 2007 11:28 PM
Yup, Premium grade (you know, the best choice offered in the states 91,92,93).
weekendrider May 23, 2007 11:56 PM
Australianpremium is 95 octane
trispeed May 24, 2007 01:55 PM
funny, my shop manual states 86 or above. 1993 usa model. That would be anything here, as the lowest grade is 87. Unless you are experiencing detonation, you should use what the manual says; for us in the states, it's 87. It works great for me, I can lug down to 2000 RPM in top and pull away without any pinging. 47 MPG (US) overall.
FYI, the debate is over, lower octane equals more power; the higher octane numbers have increased resistance to detonation, allowing higher compression, etc. There's actually less energy per unit of higher octane fuel.
No, you can't hurt anything by running higher than necessary octane. Just spending more money and getting ( ever so slightly) less power.
You can screw things up by running AV gas, like some neanderthals believe will give them more power.
WhiteHawk May 24, 2007 02:28 PM
My 1987 1kf manual stated 91 octane :p
WhiteHawk May 24, 2007 02:30 PM
But if you really had to, in an emergency, you could probably run 87 octane if you don't load your bike...or find a hardware store and put in a couple ounces of Toulene (poor man octane booster) or Dry Gas (the alcohol should help raise octane a little).
GARMIN1000F May 24, 2007 03:37 PM
always wanna use supreme b/c it is triple screened where as the regualar octane gas is not.
Trips May 25, 2007 02:29 AM
Ahh good ole Toluene,
I used to run a GSXR750 with adj advance and hi compression on pure toluene. :D
weekendrider May 25, 2007 12:19 PM
What do you pay for you fuel
