What size bolt/screw?
Old Aug 31, 2011 | 09:38 AM
ThaBrock's Avatar
Default What size bolt/screw?
Anyone know what size bold/screw goes inside the front fairing? Or is it one of the twist fasteners for the side covers?
Mine fell out or were left out by the P.O.
Old Aug 31, 2011 | 10:16 AM
Sprock's Avatar
90001-MN8-000 (5x12) I believe
are the inner threads still on the receiving end ?
Usually if these screws are missing the whole piece
is gone the screw and the receiver
it's JBweld in the receiving end drill a small hole and
self tapping screws ! the way I did it anyhow
Old Aug 31, 2011 | 12:05 PM
ThaBrock's Avatar
I'll try that size.
I can not tell if the threads ate still in there.
Old Aug 31, 2011 | 12:40 PM
ThaBrock's Avatar
I took that recommendation to the hardware store and they couldn't make heads or tails of it.
Old Aug 31, 2011 | 01:51 PM
Sprock's Avatar
it's metric and it's the oem description as is the oem part number
Most Harware Stores won't have any clue
Basically it's a fine thread metric number 5 pan head machine screw
something like this LINK
edit : some ebay listings
You really need to find if the other end is in the fairing or not
or you'll be wasting your time putting any screw in there as
there might not be anything for it to grip !
edit ....... I got fed up looking for the same when I was missing
some and as I said just filled 'em with JB Weld .... drilled a hole
in the JB Weld and used coarse screws (Not too long ) to do a
better job imo.
Guess you could say I just got sick of screwing around with it ! lol
Old Aug 31, 2011 | 02:52 PM
ThaBrock's Avatar
better job imo.
The holes do have some sort of threaded mechanism, they are holding fine.
I found one still in the fairing... waltzed it into ace hardware and found it but in a torx style drive, hardened finish (probably rust all to hell but who cares). DONE! honda wants $2.50 a screw. A.H wanted .42 cents a screw.
dodger79
Oct 13, 2012 01:22 PM
kazspeed
Mar 25, 2011 09:10 AM
HBcarnut
Oct 22, 2008 11:16 AM
Drake20
Mar 9, 2008 01:00 AM
