what else can cause clutch slippage at high rpm
on
Clutch kit there Charly for all the reasons outlined above , but ya might buy time just
going easy on her until you get your kit in August
use a 20/50 weight in the mean time might help a "lil' " bit
Sounds like somebody put energy conserving "stamped" moto oil in there and the plates
have become glazed as a result ....imo
Just a thought - one of my mates was complaining about clutch slip at high rpm's a while back.
I rode his bike and couldn't feel it at all.
Turns out he was sub-consiously squeezing the clutch lever when warp drive kicked in at 7K.
A slight change of riding style later and no more clutch issues.
ill try to look at my hand when i get rolling, and i did the roughing up on the all of the plates cause they were as slick as glass it was raining last night when i got the clutch back together ill be trying it out today in a bit ill let yall know how it goes.
thanks again for all your info
Try a set of +10% harder springs in the clutch - slightly heavier lever but quick to fit and pretty cheap.
![Big Grin](https://cbrforum.com/forum/images/smilies/biggrin.gif)
![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
It's probably cheaper in the long run to buy plates and springs as a set but clutches are another thing that I'd never buy cheap makes (like tyres and chains). I think you get what you pay for in some cases.
i am soo happy the scuff and clean and soak in the correct oil did it its a night and day difference no slippage and all power in the powerband i am still planning on getting an ebc performance clutch kit with springs and steels in august but hopefully this will work until then
i really wasnt expecting that to work but it did if there is anyone else with the problem of running the wrong oil then their clutch starts slipping just soak everything in coleman lantern fuel "aka white gas" and use like 80grit sandpaper or concrete to scuff the plates and steels lightly then let soak for like another 5 hours and when you take them out you will notice that the color will change from a glassy black to a dull gray then use a toothbrush to make sure you get any and all grit off the plates. then soak in the correct oil for like 6 hours and reinstall.
anyway thanks again for all the ideas their priceless
thanks again
james
thanks again
james
