-   CBR 1000F "Hurricane" (https://cbrforum.com/forum/cbr-1000f-hurricane-38/)
-   -   water pump??? (https://cbrforum.com/forum/cbr-1000f-hurricane-38/water-pump-97623/)
davydave Jul 21, 2009 04:59 PM
water pump???
hi guys.im getting coolent in my oil,and think it might be the water pump?engine is running fine,which is why i think its the pump.any checks i can make to test this out would be great,before i have to hand a large wedge of cash to my local honda dealer!!!
Sprock Jul 21, 2009 05:37 PM
Dave , stop by the intro in the saloon , say hi , give some details like year miles
history if know etc.........best place to start out man and the welcome crew are
always hanging around with good advice and a welcoming handshake.
Easy with the trigger finger Bud
Oh and a pic says a 1000 words
kilgoretrout Jul 21, 2009 09:18 PM
Dave,
When this happens, there are a couple possibilities.
One is that it's the water pump seal like you said.
What you want to do is drain the coolant and oil, and remove any plastic over the water pump, and replace the pump and seals. It'll be on the left side of the bike. I'm not sure if it's as simple as just replacing the o-ring between the water and oil pumps or if the inside bearing/seal on the impeller shaft of the water pump could be the source of the leak.
Either way, it shouldn't be a tough fix. I would download the manual and just do it.
If you pull the water pump out, you may be able to tell if it's the problem.
The other possibility is that it's a head gasket.
If your exhaust smells a lot like burning coolant (kinda sweet smelling... like burning coolant..lol), or if you're seeing white smoke out the exhaust, then it's a pretty dead give away that it's your head gasket.
What bike do you have? I'm guessing a CBR100F?
I guess the other possibility is that the seals in the oil cooler are bad, but I think that generally ends with oil in the coolant rather than the other way around. Higher oil pressure there..
I would get a manual and go from there.
You can download one in the how-to/tech section.
CBRclassic Jul 21, 2009 10:34 PM
Yer , a few details would be kool mate..:icon_shrug:
but anyways... Dave , me ol mate:icon_biggrin: ...one way or the other ,
DON'T RUN the engine too much while it is like that..!!
Yer ..until the water in the oil starts destroying bearing :icon_doh: which it don't take long to do !!!:eek:
If she was mine, I would do a compression test first!!.. because allot of the time with blown head gaskets , even when they are only blown across the water jacket , you will be loosing compression...
Doing that test will eliminate the head gasket to a degree before you go ripping things apart any further..
and again...don't ride her like that or run the engine for more time that you absolutely have too...
Let us know how you go...
toddmonster Jul 21, 2009 10:39 PM
you would be better off doing a leak down test this will tell you exactly where the problem is refer to your owners manual for details on this test!!!
kilgoretrout Jul 21, 2009 10:55 PM
Yep, I'd heed Classic's warning on this one. In fact, I wouldn't run the engine at all until you figure out what's going on and fix it. You can screw an engine up pretty bad in little time.
And after you do find the problem, I'd flush out the oil a couple times, too.
toddmonster Jul 22, 2009 10:43 AM
this all good imformation the last thing you want to do is run the engine with coolant in it, it is probebly coming from the water pump gasket but a leakdown test would take away all of the guessing you will be able to hear where the air is leaking into the engine and where it is going!!! a compression test will do almost the same thing but it is not as thorough of a test, however the equipment for a leakdown test is hard to find and in some cases quit expensive which is strange because it is just a beeefed up comp testor
kilgoretrout Jul 22, 2009 10:51 AM
This is true.
From the original post, I didn't think he would have access to a leak-down tester. (maybe no compressor, either?)
It seems that the water pump and seals would be an ok place to start, especially if you could get one on fleabay or something. Definately not cheap from the dealer ($200+ for the part?), but I think you can get an aftermarket one for $100-$150? Still some money, but the dealer could just swap it and soak you anyway...even if it's not the problem.
davydave Jul 22, 2009 04:14 PM
water pump?
hi guys i did post this before but it seems to have gone awal!!
my 1990 fl with 46000 miles has stated to turn its oil green!i think it might be the water pump,but not sure!the bike runs fine,no misfires or steam from exhaust,so dont think its the head gasket.no sludge on rad cap.very slightley oiley in the rad though!any thoughts?:icon_doh:
hawkwind Jul 22, 2009 04:21 PM
I think this may be your lost thread Dave
