Vibration??
Old Jun 21, 2008 | 04:06 PM
Andy1000fl's Avatar
Default Vibration??
Hi All got bit of a problem with my FL in that I have a vibration coming through the foot rests @ 4000 to 5000 rpm wasnt there when I first had the bike can anybody point me in the right direction
Andy
Old Jun 21, 2008 | 04:58 PM
MarkR's Avatar
Default RE: Vibration??
I would do a balance shaft adjustment first
Old Jun 21, 2008 | 09:26 PM
+1 on MarkR. Sounds like the perfect place to start, and very easy to do. Search the forum for it.
Old Jun 21, 2008 | 10:32 PM
Luis CBR1000F's Avatar
It occurs to me that also wheels alignmente and balancing, probably also a bend wheel rim. my two cents.
Regards and V's,
Old Jun 22, 2008 | 02:42 AM
MarkR's Avatar
If you pull the clutch in and it goes away, it's not in or pass the drive chain (Wheels chain or sprockets)
If you rev it with the clutch in and vibration come back at 4k then it's in the engine.
There a good thread about doing the balancer adjustment - pictures and everything.
Old Jun 22, 2008 | 03:52 AM
Ferlev's Avatar
Hi All, MarkR, do you have a link to the thread about balancer adjustment?
Thx..!
Old Jun 22, 2008 | 05:03 AM
Aracanth's Avatar
Hi everyone,
I adjusted the balancer yesterday, and found two things that were a bit strange. First the manual says "anti-clockwise till it stops" well, mine just continuously turns, and I managed to induce an oil leak, as the shaft moves out of the casing a little. I managed to stop it by pushing on the shaft, didnt move much but it stopped the leak, cos I had nightmare visions of sump removal! Just take care under there......
Ara
Old Jun 22, 2008 | 08:50 AM
DRam's Avatar
Very Honorable Most Senior Member :)
Same here on my first try. It was a little spooky trying to find where the shaft stopped turning and it never did. If memory serves correctly, the shaft should be turned until slight resistance is felt, and then turned the opposite direction a short distance -two notches? I set mine by trial and error: move the balancer to tighten, fire up the engine, shut down, move it, etc. until there was no vibration. At that point, though, there was a loud whine sothe shaft wasbacked off until the whine disappeared. That left just the faintest bit of vibration.
Old Jun 22, 2008 | 11:31 PM
Andy1000fl's Avatar
Thanks poeple from what I have read it sounds like the balance shaft I will adjust it after work tonight and let you know how I get on
Cheers
Andy
Old Jun 23, 2008 | 03:45 AM
Ferlev's Avatar
Hi ANdy, I did this yesterday on my 91 1000F. First I tried with the engine off, couldent feel any stop, so started the engine and tried again. Now there was no doubt, you could easily hear when you should stop. I haven't had a ride yet, but hardly can't wait.. !
