valve adjustment tool and other stuff
Motion Pro makes a tool for doing valve adjustments on screw type tappets. Will this work on our engines?
http://www.ronayers.com/catalogs/pu/...5&type=594
I'm also thinking about getting this for easy carb syncs. The number one hose would have to be have a "T" for the pet **** vacuum
http://www.ronayers.com/catalogs/pu/...5&type=584
I wonder if this would work for adjusting the idle mixture screws?
http://www.ronayers.com/catalogs/pu/...5&type=598
I love tools [sm=drlove.gif]
That idle mixture tool is a pricey toy. If it is running fine at idle why mess with it. You know the old saying...... Also I believe your year has the āDā shaped screw.
I don't know if there is enough clearance for that valve-adjusting tool, especially for the exhaust valves. Hopefully someone has the experience to say Ya or Na.
As for the carb sync goodies, how often do you do that? I check mine 15 to 20K miles and they are never that far out. When it's time to do them, I pull thevacuum hose from the petcockand hook itinto the gage. Ihook my vacuum tool to the petcock and draw a vacuum to open the fuel to the engine. On mine #1 is easy to get to, #2 is to the petcock, #3 is not so hard and #4 can slap me in the face.
I love tool also but I see things differently than you with these tools.
Total $63.51 plus shipping = about 4.5 tanks of fuel @ $3.00/gal = about 900 miles of open road.
Some choices are harder than others.
The motion Pro Tool will work fine as it has 3 & 4 mm Square adapters.
The hoses are a great idea and save you a lot of time with the carb synch, especially if you have big hands. I use em.
That idle mixture screw will only work if you have screw adjusters. Most of you guys in the States& Europe have the "D" shaped mixture adjusters. I just adjust mine when they are off the bike as per manual.
That's right I forgot about the "D" shaped adjuster on carbs. Adjusting them on the bike is better, and is done in along with the carb sync.
I might try this tool and see how it works. I think I'm due for a valve adjustment here soon.
Cain and sprockets are going on this week. I've got the bike on the new lift ready towork on it!
ORIGINAL: Trips
Malbojah, does it look like the one I linked? From what you say it sounds like the handle interfers with the head casting? In other words the tool needs to be deeper?
ORIGINAL: Stray Cat
