Using a GPS
Using a GPS
Can anyone supply any mounting tips or usage tips for installing a GPS on a cane? Im looking at getting one, but the internal batteries only last 4 hours or so and I think hooking one up to a cigarette lighter might be the best way to go. Where on a hurricane is the best place to hook up a cigarette lighter? Fuse box or right from the battery with a in-line 10amp fuse maybe and run the wires along the tank??
RE: Using a GPS
As far as I know you can't mount a GPS on standard CBR bars - guys who use the GPS generally fit streetfighter-type bars. Best power point is from the LHS fusebox, safest option IMHO-no wiring under the tank, straight up to the bars. Using bike power is a MUST - my car GPS goes flat in under 4 hrs on rechargeables. Fit an extension aerial on the tailpiece - gives better satellite reception and accuracy.Good luck !
RE: Using a GPS
RE: Using a GPS
One more...
https://cbrforum.com/m_113321/mpage_1/key_/tm.htm
https://cbrforum.com/m_464411/tm.htm
RE: Using a GPS
Sure you can! R.A.M has a mount that attaches to the screws holding the hydraulic fluid container/clutch lever, I've got one for my CBR, with a waterproof box where I put my cell phone which has GPS software. R.A.M has a BIG arsenal of holders for GPS. Check this out: R.A.M mounts
RE: Using a GPS
I use a R.A.M. mount as Mikekop mentioned. I installed a Powerlet connection in the steering stem ALA this link:
http://www.powerletproducts.com/prod...a_steering.php
Works wonderfully and I use the Powerlet connection for my heated jacket. Win Win situation.
Robert Bashaw
www.RideHSTA.Com
LoweST Arkansas
CBR1000F
ST1100A2 STovokor
VFR800A5 Interprize
Robert Bashaw
www.RideHSTA.Com
LoweST Arkansas
CBR1000F
ST1100A2 STovokor
VFR800A5 Interprize
