Using Center stand
RE: Using Center stand
They are a little tricky to get up. With the correct technique it helps. The way I get mine up is to place my hands like idodirt says. I use a two part method. I first push the bike back with left hand and right foot, dropping the center stand until the bike stops and starts to roll forward. As the bike comes off the center stand the forks compress and that is when I make the big move and pull back on the left bar as I push down on the stand at the same time lifting the grab bar. The compressing of the forks helps to get rearward motion and the bike goes up with little effort.
I guess the mock or first step helps to get the body in the proper position for lifting and leverage to get the bike rolling backwards. When done correctly, you won't believe how easy the bike goes up. It is in the timing. It is the hardest bike I have owned to put up on the center stand but sometimes it just flies up.
Note: I keep the handle bars turned full left to steady the bike. I may have them straight in the first step but they are turned to lock when I make the big move.
Edit: The faster the bike is traveling backwards, the easier and faster it goes up. Keep pulling on the left bar as the bike is going up.
When mine goes up there is so much backward motion and backward force that my rear tire smacks the ground before the bike comes to rest on the front tire.
ORIGINAL: MarkR
I can't do it with thongs or slippers, boots ok, havn't try runners.
Guest
Posts: n/a
ORIGINAL: bicklebok
Can any of you get your bike on the center stand by yourself?
I know there is a technique and I have practiced on my smaller bike and can now put it on the center stand by myself.It weighs 480 lbs. My brother can now put his FZ1 on the center stand alone with ease. But, I justcant do it with the Hurricane yet. Is it possible?
you can always park her on a very slight uphill angle .. that helps heaps if you are not 6-1 and 215 lbs :-)
