Upgrade Paths for the CBR1000f
Naga Please elaborate on the post I moved to this thread.
And guys if you see something in the list that doesn't look right speak up everything is up for debate here and should be a consensus of the forum.
Thx again for the input guys. Lets keep them coming.
What about stuff like suspension? When I repair my forks should I upgrade to mk2 or mk3 or aftermarket or stick with OEM?
Moved to this thread:
OK so this is common on all models? So my next question is what heads will fit what models and what would be the optimum combination? If I need to replace my Mk1 should I use a Mk2 or Mk3?
Mk1 - Use Mk1
Mk 2-3 - Use Mk 2-3
With the Coil stick upgrade would that free up enough room for the above question's answer to change?
Don't know - never done it. But remember there is difference in the Tank, the water pipe feeds, the thermostat assembly, the routing of the throttle cables ..... to consider also.
Yeah I knew I was dropping my neck in a noose with this one but seeing all your great DIY I can't say no.
I have other questions as well so I might as well put them here.
I read the carburetors will not fit do to the brackets not lining up but will the newer carbs just bolt up to the older brackets and would that be a worthwhile upgrade?
Or should we look to another carb to upgrade to if we need replacement carbs? I don't even know what year Fuel injection started in bikes. :icon-doh:
It seems like every system has changed over these iterations. brakes,body... I think this list is going to get very long.
Mk1 - Use Mk1
Mk 2-3 - Use Mk 2-3
You could go OEM from e-bay, but It's pot-luck.
I used a Hagon rear damper and Hagon progressive front springs when I did my suspension with standard weight fork oil.
Personal taste but some people go with a heavier fork oil up front.
A cheap fix for the front forks is to replace the factory spacer with something larger to stiffen up the front springs. Even adding extra washers could help.
No cheap fix for the rear though, if you want to get rid of the wallowy feel out of the corners the rear will cost £300/$450
Most springs and dampers will be shagged after about 30-40,000 miles so replacement will depend on location.
Most e-bay stuff is f*cked and will need replacing after a couple thousand miles anyway.
I have a slightly different view of the front forks. Adding longer spacers to the stock spring does not make them stiffer (fixed spring rate) it only eliminates the preload making them feel stiffer over small bumps. I would also caution away from a progressive spring as our forks do not have enough travel to properly utilize the progression. I ordered my springs from here SonicSprings.com They have a calculator to help you figure out the proper rate for what you do.
Hagon is what is available here in the UK and are a well respected suspension builder, in the US you may have a better /cheaper option, but unless you're lucky enough to find a low mileage used OEM shock cheap, after market is the best option.
Yea the springs are from sonic springs. All springs need spacers for preload. I would just not recommend adding a longer spacer to stock springs. There is a ton of info on sonics website on the right spacer length choosing a spring rate ... They also had great customer service as I had a few questions. I was very happy with them.
Most of the list I had are really a matter of personal preference for brand, type etc.
and not really looking to write a book on it. We all have preferences for rubber
seats grips bars - you name it - I just listed things I felt I needed changing for my
own selfish reasons. Plus the different generations of bikes kinda require diff
tweaks - for instance where I have the 3 gens - I don't feel the need to put the
wider rims and rear tire on the 87 as I like the way it rides as a contrast to the other
two ( it turns and is much more nimble doing so) but if it was my sole bike - ppphhfft
I'd probably put wider rims on it with Michelins as opposed to stock with
Conti Motions so really imo there's no template - just a lots of choices
BTW I went with Slik Designs extendable mirrors - I had to "make fit" the gen2 gen3
Gen 1 could be done but would be even more work
