Temp switch for fan
Old Dec 6, 2008 | 12:53 AM
Shadow's Avatar
Default Temp switch for fan
Could be useful - I may buy one too !
http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
Old Dec 6, 2008 | 01:11 AM
Naga_Thai's Avatar
Default RE: Temp switch for fan
Hi Pete - Good find but FYI - IMO - Take Care - this is false advertising.
They say ....
"This Low Temperature Fan Switch upgrade reduces the cooling fan's activation temperature to
80°C / 177F from the stock setting of 102°C / 216F, thus improving the radiator's cooling efficiency."
Reality is that our standard operates in spec @ 80 to 84 degrees C. See Manual page 21-5.
Or look 2 attached excerpt...
http://picasaweb.google.com.au/Naga....ey=omzH1Ca19hs#
Old Dec 6, 2008 | 02:29 AM
Harry_T_Hamster's Avatar
After reading the auction
"Attitude will not be tolerated at all."
Along with the comments he made after getting neg feedback, I dont think I would buy anything of this guy
Old Dec 6, 2008 | 03:45 AM
pacojoseph's Avatar
ORIGINAL: Naga_Thai
Those numbers refer to the temperature at which the thermostat starts to open, not the temp that the fan kicks in at. I wouldn't think that the fan kicks in until after the thermostat is fully open at, according to the manual, 95 degrees c.
Old Dec 6, 2008 | 06:04 AM
Naga_Thai's Avatar
pacojoseph
Your quite right - I re-read the manual... Fan "ON 98-102 degrees C" thenoff "Stop Open 93-97 degrees C".
Thank god were all here to check on each others interpretations to get things sorted.
What dose all this then mean???? IMO...
[ul][*]STANDARD HONDA SPECS - Current optimal operating temp = 80 to 95 degrees C (See both themostst operational temp - fully open @ 95 degrees C and Fan switch off @ 93-97 degrees C). [The themostat opens @ 80 degrees C before the fan switch comes "ON"][/ul]
[ul][*]WITH NEW ALTERNATE FAN SWITCH - The fan will come on @ 80 degrees C,as soon as the engine reaches theminimal operating temperature of80 degrees C. [ the engine would never get above MINIMAL operating temp ???] [/ul]
Think I stick with the standard Honda specs and just make sureI have up to date fluid and a radiator that's clean of bugs and other crap that gets caught in it.
Old Dec 6, 2008 | 06:59 AM
DragonCBR's Avatar
Good morning gents
it has been a while i have been extremely busy; switch, keep the original one then overide it with a manual one, if need be all you have to do is flick it on an you cool while your in trafic and as soon as you roll you can turn it off that is whatI do,I'll post pics.
Old Dec 6, 2008 | 08:56 AM
Shadow's Avatar
Bonjour Carl,mon ami !
Where have you been hiding ?
Some pics of your switch placement would be very nice.
Temp here in traffic gets quite high, esp in summer months (now)
My only concern would be draining the battery......??
Did you receive your cd's - parts list ?
