Temp sender unit
Old Apr 15, 2009 | 11:55 AM
Shadow's Avatar
Default Temp sender unit
I found a replacement temp sender unit at my local spares shop, and decided to remove the old one from the thermostat housing, to be sure what I was buying was the correct size ......AAAAAAAAAAAAAArrrrgggggggghhh !
Bastik thing had been in there 19 years and is made of brass...........sheared it clean off !
Bike doesn't leak, so still rideable, but decided to check old reliable e-Bay Motors
and found a complete thermostat unit with hoses, temp sender unit and radiator cap for $15 and another 15 for postage - BARGAIN
Needless to say, I nearly broke my own speed record paying for the thing.
I'll still attempt to extract the old thread section from my thermostat unit, which still works fine. If I can, there'll be spares available should anyone need them.......
Any tips for removal ? It broke off flush with the housing.......
I s'pose an e z out might work.........
Old Apr 15, 2009 | 01:08 PM
hawkwind's Avatar
As it's brass it should be quite easy to drill making the job easier , if thats any consolation
Old Apr 16, 2009 | 08:24 AM
Shadow's Avatar
I wouldn't have messed with it except it wasn't working..........................
I like my stuff to work, and when it doesn't I get all **** about it...............
typical 1000F owner I guess..............
Old Apr 16, 2009 | 12:26 PM
pacojoseph's Avatar
Speak for yourself. I got a tongue lashing from my 10 year old nephew last summer because my bike was dirty. Nevertheless, he still grabbed my spare helmet and said, "let's take a ride".
Old Apr 16, 2009 | 12:45 PM
Shadow's Avatar
I seem to remember something you and i discussed about dirty bikes once before...................
Maybe it's the exception that proves the rule..................
And no, I wouldn't presume to speak for you, Joseph.
Old Apr 16, 2009 | 06:26 PM
slowpoke's Avatar
Whenever there's hot water flowing past dissimilar metals like brass and zinc, or aluminum, what ever the housing is made from, you get a chemical reaction. That brass may be welded to the housing. You could try soaking it with PB Blaster, but it may be hopeless. Nice score on the one from ebay.
