TANK VENTS
Old Dec 14, 2008 | 06:09 AM
Shadow's Avatar
Default TANK VENTS
I've just had my tank coated internally to cure a persistent leak.
Beautiful, no leak BUT I'm now getting a pressure rise in the tank which means the tank isn't venting properly. Pressure builds up and the bike won't run.....[:@]
The tank has two vents, it seems -
one just inside the filler cap on the left,which flows into a rubber recepticle on the carbs, and a smaller thin diameter tube under the tank, about 25MM long, which appears blocked. I don't know where it comes out - must be near the cap somewhere.
Maybe it's in the filler cap unit itself ? Can anyone enlighten me on this ? I'd rather fix it myself, than send it back to the coating people.
Thanks
Old Dec 14, 2008 | 08:27 AM
Shadow's Avatar
Default RE: TANK VENTS
Been there, done that Steve..................
But it was blocked before it went to the coating people, but now the tank won't vent......[X(]
I'd just like to know where the skinny pipe comes out................
Old Dec 14, 2008 | 05:14 PM
Naga_Thai's Avatar
hi Pete
Fear I'm of little help too ... fear my research without tangible result and / or things you already know.
As a matter of elimination - what is NOT your vent - Attached photo shows..
BLUE - ????
YELLOW - tank fuel guage cable cover sheath.
GREEN - Pet lock vacume hose..
[IMG]local://upfiles/25866/14EAD6D0CCD24AF59100A95EF3C91A68.jpg[/IMG]
Old Dec 14, 2008 | 08:04 PM
slowpoke's Avatar
The tank is vented through the gas cap. Page 1-29 of my 90-91 Honda manual also shows venting to a canister, but that should only be on California bikes.
Old Dec 14, 2008 | 09:24 PM
Luis CBR1000F's Avatar
If I'm not wrong Pete's bike is a California model...now, on my bike, if I top up the gas level, and leave the bike in the sun for some time, I will hear some "shizzing" sound coming from the gas cap, I can even see some very tinny bubbles popping out of the ring around the area where the key goes in, this means that the gas cap has a vent also to prevent from an explosion originated from gas build up...I guess
Good luck Pete and I wish to have more wisdom in my back to help you the way you have helped a lot more!!!
Old Dec 14, 2008 | 10:06 PM
Shadow's Avatar
Thanks guys - appreciate the effort.
Luis - sounds like what I'm looking for - with the new ceramic coating the tank cap is an airtight fit, which may be the problem........
If all else fails, use a drill...................[X(]
Old Dec 15, 2008 | 02:52 AM
Bazman's Avatar
Hey Pete.
I've got a dented tank ( beyond repair )I can try to crack open to see what's what in there if you have no joy sorting it.
Let me know...
Cheers.
