subframe/seat upgrade
Old Mar 29, 2006 | 08:50 AM
acer's Avatar
Default subframe/seat upgrade
hi, has anyone here previously modded their CBR1000f to take a newer seat off a super or hypersport model (ie like a 954rr or similar)
What would you have to do. I know its not an easy it/swap.......The frames are obviously different, placement of battery would be a consideration etc.
any information would be great
cheers...jas
Old Apr 19, 2006 | 12:46 AM
el_super_dan's Avatar
Default RE: subframe/seat upgrade
hey,
I am currently doing that mod right now. I am using a sub frame from a 2004 f4i and an under tail exhuast from a bmw. I just started this project on Easter Sunday so I will update you when I finish.
Old Apr 19, 2006 | 01:06 PM
stinky93071's Avatar
post up some pics of what you are doing sound cool..
Old Apr 19, 2006 | 01:45 PM
grwilson6's Avatar
ya i've mounted a 1000rr tail section/subframe on my 87 hurricane. i still need to paint the new frame i made to match the stock frame but this is where im at so far.
Old Apr 19, 2006 | 05:15 PM
i like that.. are you going to run old plastic on the bike? what are you plans for the pip? and what swing arm is that?
Old Apr 19, 2006 | 07:12 PM
grwilson6's Avatar
ive got an undertail jardine from the 1000rr to run. im not gonna use the old plastic and the swingarm is off a vfr 750.
Old Apr 27, 2006 | 04:19 AM
hey grwilson6,
How hard was it to fit the swingarm? That looks bad ***.
Old Apr 27, 2006 | 12:13 PM
darkstar7's Avatar
Please tell us how you did the swingarm. that is sooooooooo sick
Old Apr 27, 2006 | 03:38 PM
grwilson6's Avatar
well i had to make spacers because the vfr swingarm was a couple inches narrower and i also had to make new bushings because i used the hurricane pivot bolt and it was a smaller diameter then the vfr pivot bolt. then i had to notch the frame so that the shock would clear and make the shock mount. i dont have the measurements for the bushings or the spacers but next time i take it apart to paint i will measure everything. you can kind of get the idea with these pictures but i will take some more next time i can.
Old Apr 27, 2006 | 03:39 PM
grwilson6's Avatar
heres a couple more
