still running the stock brake lines?
Old Feb 12, 2020 | 09:04 AM
forestfarm's Avatar
Default still running the stock brake lines?
Are you guys still running the oem brake lines on your bikes?I have to rebuild my rear caliper in the spring,its dragging lightly.Was wondering if i should get a stainless brake line while i have it drained.My BMW RT1100rt has known problems with the brake lines deteriorating internally and acting like a check valve essentially locking the caliper after hard braking,i havent had the problem yet but its in the back of my mind.The brakes are fine on my hurricane,just that the rear disc is kinda warm when i stop the bike after not having used the rear brake in a while.The fronts are cold.Thanks
Old Feb 12, 2020 | 10:15 AM
74demon's Avatar
I'd replace it. I'd replace all of them. Stainless brake lines are huge for increasing brake performance. Hell, the line might even be why the caliper is dragging.
Old Feb 12, 2020 | 11:29 AM
forestfarm's Avatar
I ordered galfer ss lines as soon as I posted it,I answered my own question but you confirmed it.Thanks
Old Feb 19, 2020 | 09:12 AM
Razman's Avatar
I think I also have one that is dragging, did you order a complete set? How much was it? Are you keeping the stock functionality of the brakes intact or eliminating the linked system?
Old Feb 19, 2020 | 11:41 AM
forestfarm's Avatar
The line was $50 Galfer SS from ebay . just for the rear,kind of expensive but it is a long line,plus their fittings and hardware are top notch.My 87 Hurricane does not have linked brakes from the factory.
Old Feb 19, 2020 | 11:52 AM
Razman's Avatar
Ah, gotcha. My '96 has linked brakes and I dread the though of having to replace all the lines.
Old Mar 7, 2020 | 06:45 PM
forestfarm's Avatar
Default Rear Brake issue identified
The rear caliper pin was corroded and binding,just cleaned it up and lubed.Will order new pin as it is pretty well pitted.I replaced the aftermarket pads with NOS Honda pads.I had ordered a full caliper rebuild kit as well as a new stainless line but didnt see the need at this time.The stock brake line looks pretty well designed,its still appears to be in great shape.More spares to sit on the shelf.
Old Mar 7, 2020 | 08:21 PM
74demon's Avatar
Stock rubber lines usually look good on the outside. Its the inside rubber that swells in brake fluid and causes restriction. Since you have the line, change it.
in one of my auto classes in college, we took a rubber cup from a wheel cylinder and put it in a cup of brake fluid. Then put in in a cupboard for the duration of the class. It almost doubled in size...
Old Mar 8, 2020 | 08:16 AM
forestfarm's Avatar
I will wait until the new pin arrives.
pricey797
Mar 21, 2014 04:05 AM
Lildude71
Mar 8, 2011 11:05 PM
CoreyAkaOpie
Feb 26, 2008 12:31 PM
Nye
May 23, 2007 03:59 PM
driber
Oct 14, 2005 10:05 PM
