Steering stem adjustment nut
Old 02-06-2014, 03:59 AM
wheelnut's Avatar
Welcome Crew
+ 1 as above, i usually tighten the nut down tight but not too tight too make sure the bearings and seats have tightend down then loosen the nut off and tighten it whilst checking the free movement of the steering, if you want to set it up using the torque setting if you use a c-spanner a 1ft piece of pipe with a hole drilled in the end, slide it up to the neck of the spanner and use a set of fishing scales to measure the foot/lbs but make sure you tighten the nut then slacken it first to ensure everything settles
Old 02-06-2014, 08:51 AM
ShoneKg's Avatar
I made it myself, the pictures say it all ... It's pretty easy.http://postimg.org/gallery/9hozb498/1a98629c/
baseballkid
10-23-2012 06:29 PM
some guy #2
09-18-2008 10:56 PM
EGGBERT
01-28-2008 06:51 PM
Chunk3rs
10-16-2007 01:42 AM
06CBRF4i
08-30-2007 02:14 PM
Quick Reply: Steering stem adjustment nut
