sprocket and chains ?
Old Nov 14, 2007 | 11:39 AM
DragonCBR's Avatar
Default sprocket and chains ?
Good day everyone
What is the brand of sprocket and chain that you use, which one is the best, OEM, DID ?
Thanks for the input
Dragon64
Old Nov 14, 2007 | 05:27 PM
Griffin's Avatar
Default RE: sprocket and chains ?
Mine are original. I do need to replace the chain however. No idea what would be best, though.
Old Nov 14, 2007 | 05:46 PM
ArTravlR's Avatar
1990 parts catalog says:
Chain:
Takasago "RKK50LF0X114LE ---- 405A3-MM5-670"
or D.I.D. "50ZV-114LE ---- 405A3-MM2-003"
Chain Drive DID Upgrade or EQuivalent DID Code {EQ} 50(530)ZVM2 X 114 links CBR1000F [89-95]
17T front Sprocket ---- 23801-MM5-000
and 41 or 42 or 43 rear sprocket ---- (my case 42T 41200-MS2-000)
I use DID & order parts online
Robert Bashaw
LoweST Well Oiled Arkansas
CBR1000F
ST1100A2 STovokor
VFR800A5 Interprize
Old Nov 14, 2007 | 07:24 PM
vulcanman72002's Avatar
artravlr,
did you serve in the 392 chem recon unit. If so I served with you.
Old Nov 14, 2007 | 10:59 PM
ArTravlR's Avatar
Yes
Robert Bashaw
LoweST Small World Arkansas
CBR1000F
ST1100A2 STovokor
VFR800A5 Interprize
Old Nov 15, 2007 | 08:09 PM
Trips's Avatar
I use cheep ole JT Sprockets and a ek chain. Got 20k out of em
Old Nov 17, 2007 | 01:24 AM
BLUE1000F's Avatar
Have not changed my chain or front sprocket yet but i "uppgrade" the rear size toa JT sprocket(45).
Old Nov 21, 2007 | 01:07 AM
simtech's Avatar
hey Blue, does that 45t sprocket give you lower highway rpms ?
Most of my rides are on interstate 75-80 mph and wondering how I can bring the rpms down from 5k
Old Nov 21, 2007 | 03:39 AM
BLUE1000F's Avatar
I would not say lower...in theory itshould be higher rpm's at the same speed.
I wanted more torque to the bike that's why i changed it from 43 to 45. I don't remember how much it increases the torque but from original 42 to 45 it should increase around 6-7 %...if i remember correct.
Old Dec 22, 2007 | 03:26 PM
DragonCBR's Avatar
wAnyone ordered them online ?
