Spot the difference
I win. In 2006 you didn't own some kind of crazy blooby thing on your garage door and you didn't own a Black & Decker Workmate. I'll pm my details to pick up my prize
Never happen with a Nonfango system..................
But to answer your question,
you bought your fold up workbench in the past few years.
I want a prize too..........
Dammit!! I'm too late.
Maybe the prize is the Workmate??
Seriously though karlo, that's a pretty silly design fault mate. As I see it, your choices are; 'modify'
the Wingrack or take the actual lock part out of the seat catch and fashion some kind of lever instead.
Maybe a combo. Pull the lock out, drill a hole in the side of the Wingrack just big enough for a long screwdriver to be put in and operate the catch??
Can I have the prize now?
the Wingrack or take the actual lock part out of the seat catch and fashion some kind of lever instead.Maybe a combo. Pull the lock out, drill a hole in the side of the Wingrack just big enough for a long screwdriver to be put in and operate the catch??
Never happened with the Sprockie engineered version either
But hey thats nutz....... nothing a little pull string ---as outlaw says---- would not fix tho'
Nice kitty on the garage door
Going to see if I can get a smaller key cut as both keys (OE Honda) are the same length, if the new key is the same length then it's key modding time.
I reckon it could be shortened by at least 6mm to operate the ign and seat lock or 15mm just to operate the seat lock. at 6mm still would be tight but I'm pretty sure it would work.
Every "Hello Kitty" I've ever seen before has been kinda pink and white and cute. I can only presume that the black one is the evil "HELLO KITTY" twin.
