speedometer is way off....
#21
RE: speedometer is way off....
ORIGINAL: woot
We can actually figure this out without looking at the sprockets.
If someone posts their exact speedo reading on a stock bike - 6th gear @ 5000 rpm. The original poster posts their exact speedo reading (6th gear @ 5000 rpm).
Do some basic math - do +1,0; +1,-1; +1,-2 and compare to the Original posters indicated speed - done.
No comprendo, senoir.
#22
#23
Since the amount will be fairly linear, I like to think in percentages. For instance, I know that according to my gps the indicated speed is 10% high. At an indicated 110 I'm actually doing 100. So that stays pretty constant all the way through the entire range. Except of course at 0 mph it's totally accurate.
So if your sprocket change gives you a 5% difference then it's 5% through out the range. Or close to it. So an indicated 50, you would really be doing 50-5% = 47.5 Or if your speedo is already 10% off and you change then it would be 50-15%=42.5
So given that malbojah was nabbed going 86 but an indicated 105 means his speedo was a wopping 20% off. That's huge! I would suspect that typically the CBR speedo's indicate about 10% too fast, then add a 10% ratio change that would account for the 20% difference.
Is it too much to ask that manufacturers send accurate gauges? Geez... even the temp gauge is weird! The first quarter of needle travel is 180 degrees, the next half of travel is like 20 degrees... sheesh....
#24
The speedo error is normally a fixed percentage, like e.g. 8 %. It will then show 54 km/h at 50, 108 at 100, 216 at 200and so on. If the front sprocket is changed from 17 to 16 tooth (17/16=1.0625) , that will add 6.25 % to the error, i.e. give 14.25% misreading in thisthe example.
#25
ORIGINAL: Stray Cat
With the newer electronic speedometers, a couple of companys make a tool that going inline with the speedo hookup that allows you to change the reading to help correct some variables.
And I would be happy with an accurtate fuel guage.
When I dynoed my bike a couple of years ago, I took it all the way to the top (185) and the dyno report 165mph.
#26
That was the point...
The measured mile works however.
Set the odo to 0. Ride a highway with marked distances. Ride 10 miles (100 is better). Comparo odo to the mile marker.
12 miles on the odo, 10 miles on the sign - that's your error.
READ - REAL divided by REAL
(12 - 10)/10
2/10
+20% error.
#27
ORIGINAL: R1000
This is becausethe transmission is a fixed set of ratios and the sprocket ratios are fixed.
05, 600, actual, cbr, f4, fix, honda, hurricane, odometer, slower, spedometer, speedmeter, speedo, speedometer
