screw
Old Oct 4, 2008 | 05:21 PM
Devastation's Avatar
Default screw
hey if any one has a screw that holds in the middle fairing in to a 94 cane 1000f, and could part with it let me know,i sure could use it.
[IMG]local://upfiles/29030/C7CF7D1510D74A0B827F73DA53686074.jpg[/IMG]
Old Oct 4, 2008 | 06:35 PM
MarkR's Avatar
Default RE: screw
The clip broke on mine and I used a spring washer, then squeezed it a little so it wouldn't come off
Devastation, I know this is not what you were looking for.
Old Oct 4, 2008 | 10:53 PM
Shadow's Avatar
Default RE: screw
Try looking under the fuse or radiator panel for one, and replace that - check previous posts on this - available on the net for about $3 each.....
Old Oct 5, 2008 | 01:30 PM
Default RE: screw
you have a link for the screw on the net? i checked under the fuse and radiator nodda there, thanks for the help though guys. i would prefer to have the right screw in it.
Old Oct 5, 2008 | 08:59 PM
fast1000f's Avatar
Default RE: screw
its the half turn screw that locks instead of actualy turning till its tight, correct? cant you just order one from the dealer? i know they are rip offs, but cant be that bad, can it?
Old Oct 5, 2008 | 09:34 PM
Default RE: screw
About $7.60. The sad thing is that the shipping will be more than the screw itself.
Old Oct 5, 2008 | 11:34 PM
Shadow's Avatar
Default RE: screw
There's a previous post with pictures - about 3 months back. Also, look up posts from Daniel_arg
who found them last time.
https://cbrforum.com/m_555395/mpage_.../tm.htm#555643
Old Oct 6, 2008 | 09:53 PM
fast1000f's Avatar
Default RE: screw
you are a wealth of information shadow1, don't know what we would do with out you, probably alot more searching! lol
Old Oct 7, 2008 | 12:25 AM
Shadow's Avatar
Default RE: screw
Thanks but I misunderstood the question[X(] DOH - look at the picture, dummy !
I thought you meant the middle fairing in front, between the screen and the belly pan....
The bolt you're referring to is one of those quiklip things - maybe try
www.mrcycles.com
Old Oct 7, 2008 | 01:16 AM
Stray Cat's Avatar
Default RE: screw
Go to www.ronayers.com
Click on OEM parts - on linemicrofiche
Select Honda - motorcycle
Select year (1994)
Select CBR1000f
Click on Side Cover
You'll see the quarter turn fastner, (number 7)it's part number 64507-MN4-000
You shall now all bow to my mastery of the interwebs
