Rear sprocket size change vs. chain length
Old May 13, 2007 | 01:18 PM
WhiteHawk's Avatar
Default Rear sprocket size change vs. chain length
How much would, for example, going from a 42 rear to a 44 rear make a change to the chain adjusted length?
Right now I have this new chain/front sprocket that the previous owner installed, i'm guessing he got too long of a chain (or changed the front teeth count). I'm adjusted to the redzone...I would love more torque, so my easy and cheap solution is change the rear sprocket...I just want to get it ordered right the first time. Do you think a 44 would keep me in the adjusted range? (I have a 42 on there).
Old May 13, 2007 | 06:12 PM
collector's Avatar
Default RE: Rear sprocket size change vs. chain length
How many teeth do you have on your final drive/ and how many links do you have in your chain?
Old May 14, 2007 | 06:56 PM
Honda_Hurricane's Avatar
Hi.
You can have a 45 sprocket in the rear without buying a longer chain. The stock chain have 114 links.
If your chain is too long you just cut some links off to get it down to 114 (that is if you have a link that can be opened, or just buy such a link).
Bigger rear sprocket gives a better gearing for play!!
Old May 17, 2007 | 08:32 PM
WhiteHawk's Avatar
ORIGINAL: collector
Finally got around to it...now the final drive has 43 teeth (the big sprocket) and I counted 58 outer links (so thats 116 then eh?).
Isn't the OEM chain supposed to be 114 links?
Old May 18, 2007 | 02:23 AM
If I am not totally lacking in memory the stock settings are as follows:
1987-1988: 17/43 - 114
1989-1992: 17/42 - 114
1993-1999: 17/42 - 114
But of course if you want to do stunts you can have bigger rear sprocket (for the lasting of the chain, don't smaller the front sprocket too much) and use a longer chain.
Old May 18, 2007 | 01:13 PM
Kerunk's Avatar
On my '89 someone has fitted a 43 rear sprocket and the chain is standard 114.
But on the '98 it appears to have a standard? 41 rear sprocket and 114 chain.
You can see that the wear indicator is completely wrong now.
I did not check the front spocket, maybe I should.
Rob
[IMG]local://upfiles/9282/FBD81B20485D48DDA2E220F5D8D71683.jpg[/IMG]
[IMG]local://upfiles/9282/61B006E6A5994102AC480DC7D1BEA8A3.jpg[/IMG]
Old May 18, 2007 | 08:19 PM
WhiteHawk's Avatar
Ahaha, what is going on there? It looks like the stickers have been moved.
If I move my sticker to the good range (above the double arrow), will that fix my problem?
Old May 18, 2007 | 08:20 PM
WhiteHawk's Avatar
*Warning: Sarcasm was apparent in the last sentence of the last post.
Old May 19, 2007 | 02:26 AM
Triangle's Avatar
How long is a chain link? as in each link is__mm or inches?
Old May 19, 2007 | 06:13 AM
Kerunk's Avatar
ORIGINAL: WhiteHawk
Almost certainly! I find that moving the goalposts ensures a 100% success rate. It's only the older bike that has been "tinkered" with, the new one is I presume, spot on.
But it does show for you that the chain wasn't changed with the sprocket and does go somewhere to answering your original question?
Cheers,
Rob
