rear brake retainer clip
Old Jul 25, 2006 | 05:14 PM
billyjb05's Avatar
Default rear brake retainer clip
While cleaning the rear wheel and brakes on my 95 cbr1000f I managed to knock the retainer clip off and found it on the garage floor. It is item #12 in the attached schematic, but for the life of me I can't figure out where the thing goes? Any help would be appreciated.
[IMG]local://upfiles/9695/1CCBD54388C24C81BF6624AE68EF28C0.gif[/IMG]
[IMG]local://upfiles/9695/DC0D82B743584A0FA16E1B6B9C8427A8.gif[/IMG]
Old Jul 25, 2006 | 07:21 PM
dad's Avatar
dad
Default RE: rear brake retainer clip
You must have had the caliper off and pads removed. It straddles the caliper bracket where the pad ends push against that bracket while stopping. It's a stainless piece that takes the wear and prevents galvanic corrosion that will occur if you leave the steel pad end bearing against the aluminum bracket. You'll have to remove the caliper as if you were doing a brake pad replacement and it'll be evident where and how it goes. Hope that helps.
Old Jul 25, 2006 | 07:55 PM
Steve_Cardiff's Avatar
The clip you speak of fits against the end of the brake pads. It'll be the end of the pads closest to you in the picture. Once you figure where that end of the pads go you'll find the home of the clip.
I hope you understand what I mean.
I'll try to explain it another way too.
See the item no 15 in the pic? Well the clip you mean fits at about the 7 o'clock positon to that. Does that make sense?? Hmm, difficult one to explain, but very simple once you understand.
Old Jul 26, 2006 | 01:07 AM
dad's Avatar
dad
It actually clips to part #6. The bent tabs straddle the machined face where the pads butt. Hope that helps.
Old Jul 26, 2006 | 05:31 AM
billyjb05's Avatar
Thanks for the help, I'm headed to the garage to get this beast back on the road.
Emmanuel Lind Chrisalos
Mar 16, 2014 11:03 PM
novex
Mar 9, 2013 10:27 AM
cbrjason
Jul 23, 2007 04:33 PM
