radar detector mod
Old Sep 29, 2006 | 10:58 PM
old1000's Avatar
Default radar detector mod
ok so i have an extra radar detector lying around and i'm gonna put it on my bike. i took it apart, and now i figure i can take the 2 wires that run to the speaker, and run them too an l.e.d. and then mount that l.e.d. to the dash. will it work?
Old Sep 30, 2006 | 04:13 AM
R1000's Avatar
Default RE: radar detector mod
ORIGINAL: old1000
I guess the speaker signal is to weak to drive a LED so it can be seen in daylight and when your focus is on the road. It may glow some though, even if the speaker output is AC and the Light Diode works on DC. What you can do is to amplify the signal and then drive whatever you want, a relay, lamps, LED's etc. If you search for voice activated switch and similar, you'll get ideas and inputs for solutions. E.g. http://www.gatewayelex.com/kits4_F.htm
Isn't there any diode already on the unit that can be relocated?
mariof
Apr 1, 2010 01:45 AM
dragginazz
Apr 12, 2009 07:16 AM
ionutchelu
Sep 15, 2008 12:10 AM
rons93rr
May 2, 2008 10:01 PM
frankmackie
Jan 30, 2007 05:51 PM
