question?
Old May 27, 2009 | 08:13 PM
raiden's Avatar
Default question?
when do i need to changes the regulator rectifier? any sign? my cane wont start even if i put a new battery.. no sound click at all..
Old May 27, 2009 | 09:59 PM
Shadow's Avatar
Then its not the regulator - sounds like you've blown a main fuse.........?
Old May 27, 2009 | 10:38 PM
Could be the side stand switch or the Engine Stop switch on the right hand grip. Does your headlight come on.
Old May 28, 2009 | 01:16 AM
Shadow's Avatar
Yup, Bill's right as always.
If it wasn't 4AM when I saw your post I may have too !
Good to see you again Bill !
Old May 28, 2009 | 10:18 AM
kilgoretrout's Avatar
Administrator - Retired
Doesn't change the line much, though, shadow...
(I was gonna guess a fuse, too)
So it looks like we've got 3:1 odds on the main fuse.
(side bets are allowed on what made the fuse blow)
2:1 on the kickstand switch.
(If it's the kill switch in the off position, the OP pays the field 2:1 on all bets)
And the lonshots...
25:1 on cooked wiring
35:1 on a totally junk starter that won't even click
50:1 for two completely dead batteries.
Any update, raiden? Is the headlight coming on?
Inquiring minds want to know..
Old May 28, 2009 | 10:25 AM
Shadow's Avatar
If I was a betting man, I'd say the wiring into the main relay has probably gone a bit crooked, or the fuse in the same area.
I'll have 10 bucks at good odds.............
Old May 28, 2009 | 03:57 PM
sawnee's Avatar
Whats the odds on? "having the kill switch turned to off " LOL
Old May 28, 2009 | 05:38 PM
You must have missed that one, sawnee.
shadow,
I'll bet you $10 that I can turn you into a betting man...
Old May 29, 2009 | 12:10 AM
raiden's Avatar
[quote=kilgoretrout;790113]Doesn't change the line much, though, shadow...
And the lonshots...
Inquiring minds want to know.. [/
battery was the problem.. it drained fast.. thanks guys for ur help..
Old May 29, 2009 | 08:34 AM
Glad you got the problem solved, raiden.
Nobody bet on the 50:1. That could have been a good payout!
