power about right??
Old Apr 21, 2012 | 05:17 PM
chevychevelle291's Avatar
Default power about right??
hope this is in the right section..new to this site.. i bought my 87 hurricane 1000f 3 years ago and took it to the track( 1/4 mile) and ran a 11.7 at 118 mph.. this bike should run 10.7 according to internet specs lol.. so today i went and cleaned carbs added a k@n cleaner, new plugs adj.valves is there any other mods i can do to gain a little power and torque bike is all stock exept air cleaner.. would gearing help? going to track again in 2 weeks if weather permits.. thanks in advance...
Old Apr 21, 2012 | 07:59 PM
hawkwind's Avatar
Gearing wont increase the power, but if all you're interested in is straight line acceleration then it's the simplest mod you can do.
Have a look here Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
Old Apr 21, 2012 | 08:35 PM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
I think 10.7 might be a little ambitious, Cycle World ran a '90 (same HP as an '87/'88) at 11.2/124mph.
Bear in mind that those guys are professional riders, who don't have to ride the bike home at the end of the day, so they probably have a little less mechanical sympathy for items like clutches than the rest of us would.
So all in all I would think 11.7 isn't too shabby for a 25 year old bike.
If you are looking to go drag racing thou: Step 1 - dyno, make sure the old girl still has all the horses that were supposedly installed at the factory.
Step 2 - gearing - maybe plus 1 or 2 on the rear? someone else would be better to comment on that.
Step 3 - if still not satisfactory, get a larger wallet.
Old Apr 21, 2012 | 08:44 PM
Sprock's Avatar
Drop the front cog to a 16
Old Apr 21, 2012 | 10:42 PM
ok thankyou for the quick responses... when i was at the track i tried everything slipping the clutch my best time was just letting clutch out and let her fly..lol just trying to get it ready i even tried lightening it up alittle.. center kickstand,all reflecters so on...the air box says it has conforfs to uspea for that model year.. do you think it has restricters in rubbers or in airbox on this model what would i look for??guess i should off payed mor attention to it when i did all that work lol..lol
k thanks for the link also i just took my aircleaner back out to look at the airbox and there is a white restrictor plate just above the aircleaner would it help to take that out or would i loose power??
Old Apr 22, 2012 | 07:47 AM
bicklebok's Avatar
I agree with the others. Thats not a bad time for that bike. Sprocket change might help some.
Old Apr 22, 2012 | 11:07 AM
k so any one take out the white plastic in the airbox above the filter for better flow, or would i loose power??bike already smells rich..
Old Apr 22, 2012 | 11:09 AM
wooferdog's Avatar
Something that's true with cars and I assume bikes on the strip is that the race is won or lost in the first 60 feet. Back in the 80's Terry Vance was testing a Suzuki GS1150E, then, the out of the box 1/4 mile king, They even put nitrous on one and used the horn button as the trigger. Anyway, an easy trick is to set the rear suspension to its stiffest settings, then bottom the front suspension (even to the point of strapping it so it doesn't extend). This will reduce weight transfer at launch and result in more instantaneous forward momentum. Free and might gain you a tick or two
Old Apr 22, 2012 | 11:30 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Two things that are rarely ever correct is seat of the pants dyno and smelling correct A/F ratio
Old Apr 22, 2012 | 01:16 PM
Sprock's Avatar
Strapping and or lowering the front through the yokes can help and as pointed out
stiffening the rear to the hardest setting too. Get your weight as far forward as possible
What ya running for pipes ? Stock Pipes ? .... a single high flow might help some
