please help me!!
#22
not backwards, inlet is bottom, vent is on top between 1-2 and 3-4. at least on my 88. Another thing to look at is your float needle and seat. since just one cylinder is filling, should just be a problem in the one carb. I would take it apart again, q-tip the seat, and replace the needle. while it is apart, put the float in a cup of fuel and make sure it doesn't sink. I had a gpz900 with a leaky float. very hard to find.
#23
There looks to be three connecting pipes in the carb diagram.
http://www.bikebandit.com/houseofmot.../m2019sch20516
Without being able to lift my tank, what is the third pipe for? Could that be mis-conected?
#26
#27
on
one, some boat yards will do it for ya too.......boat motors always have comp'
checks done to them......
You say you are getting good strong spark on 2 right ? nothing grounding out ?
I would double check that needle seat on #2 carb again if #2 cyclinder is still filling
up with gas..........reading back through all the previous posts seems most probable
issue to me other than the potential sticky valve
#28
#29
Last winter I was working on a snowblower and it had a very small piece of thread in the bowl seat(needle). Fuel would flood the carb. It was very hard to find.
#30
