please help me!!
Old Aug 4, 2009 | 10:10 AM
kilgoretrout's Avatar
Administrator - Retired
Good call, DRam. I've never done the line switch before, but can see how it could happen. You may be on to something there.
Other thing is float problems like you said.
Ironman, I can also probably snap a couple pics of the placement of my vac lines and such, or at least give a description when I get home. It may help, too.
Old Aug 4, 2009 | 11:56 AM
TimBucTwo's Avatar
The petcock vacuum line comes directly off the #1 cylinder vacuum port directly to the petcock on a non-CA bike.
If you had a tear in the diaphragm, I would think that the vacuum port would suck fuel past it and into #1 and not #2.
Old Aug 4, 2009 | 01:29 PM
DRam's Avatar
Very Honorable Most Senior Member :)
True, but I wasn't talking about the vacuum line to the petcock. I meant the fuel supply line from the petcock to the carburetors and the vent line that runs from the carburetors down toward the swingarm. If those are reversed fuel runs into the float bowls through the vent port and can flood cylinders. The bike might run for a while, but will eventually flood out.
Again, please don't ask me how I know that. It's just too embarrassing to talk about.
Old Aug 4, 2009 | 06:54 PM
DRam's Avatar
Think we may have a winner !!
Don't ask ??? hmmm.... me tinks someone may have made a boo boo at some stage ? ...LOL
Just one of many. Sigh.
Old Aug 5, 2009 | 12:17 AM
Shadow's Avatar
Over the years, bikes have given me a truly colourful vocabulary..........
The 1000F is no different.sigh
Oh and TBT the petcock vacuum goes to no 1 carb on the emission bikes too.
Old Aug 8, 2009 | 01:28 PM
ironman2583's Avatar
i got the fuel lines going to the bottom of the carbs and the vent lines r on the top portion of the carbs. but now that i think about it i got the vent lines plugged cause i thought it was a vac line. oops!!
Old Aug 8, 2009 | 10:06 PM
r the carb vents the big ports between 1 and 2 , 3 and 4??
Old Aug 9, 2009 | 12:30 AM
Shadow's Avatar
Yes, and should have pipes on them
Old Aug 9, 2009 | 05:24 AM
TimBucTwo's Avatar
Backwards, the fuel comes in on top and the bowls are vented from below.
