Only firing on two cylinders....!!!!!!!!!!!!!
![Question](https://cbrforum.com/forum/images/icons/icon5.gif)
Hi, I have CBR1000fl 1990, just bought it today and when riding home its spluttering , as though it was only firing on two cylinders... Pulled into the petrol station then after 5 minutes i tryed starting it and it fired on all four cylinders and shot up the road.........
Cut a long story short, its firing on 2+3 but the 1+4 exhaust was not hot.....
It seems only to stop firing on all cylinders when i rev it hard up the road.....
Then if i leave then bike for 5 or 10 mins it fires up on all 4 cylinders......
Can anyone shed some light on my problem...
Has anyone had a simular problem....
Many Thanks Chris
Many Thanks Chris
![Icon Cry](https://cbrforum.com/forum/images/smilies/icon_cry.gif)
being 1 and 4 are on the same coil, if the coil doesnt fire it will loose both cylinders. check connections and coil resistances. try swapping the coil with the 2/3 coil. if the problem moves to 2/3 with the coil, the coil is bad. if it stays at 1/4, its something else (connection, wiring, etc)
