Oil filter from hell!!
Old Jan 26, 2010 | 03:16 PM
NE1000F's Avatar
Default Oil filter from hell!!
I'm looking for some way to get this FN thing off. So much for the nut attachment, stripped with a socket first try. I then used vice-grips but that just rounded the end. I then used the rubberband wrench but did not have enough room to turn due to the headers, lastly I used the strap wrench which only put a dent in the top of the filter.
Holly Crap I can beleive it's giving me this much trouble.
Attached Thumbnails Oil filter from hell!!-100_1260.jpg   Oil filter from hell!!-100_1264.jpg   Oil filter from hell!!-100_1265.jpg
Old Jan 26, 2010 | 03:26 PM
canhead64's Avatar
when i bought my f4 the oil filter was on so tight ihad to take a screwdriver and punch in through the filter just to get it to turn. i ended up with 12 holes in it before i could take it off by hand. stupid f*er that owned it apparently.
Old Jan 26, 2010 | 03:35 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Question
+1 on the screwdriver and hammer. Also a real oil filter wrench would work.. Be sure to oil the gasket before you put the new one back on. Why are you changing the oil now, you can't ride it .
Old Jan 26, 2010 | 03:38 PM
malbojah's Avatar
If you've got the new filter handy, head on down to autozone/advance auto and get the filter cap wrench 'F'. Fits the Kawasaki filters that I use on the CBR
Edit: don't make me get the bike ready and do a trip to your place
Old Jan 26, 2010 | 03:40 PM
bicklebok's Avatar
+ 1. off center but still has some meat to work with.
Old Jan 26, 2010 | 03:49 PM
kilgoretrout's Avatar
Administrator - Retired
I've had to do the old screwdriver through the filter trick, too. Never on the CBR, though...
malbojah is right on the money. Get a decent steel cap wrench. The pic below is very similar to mine. Then a 3/8" extension w/ 17mm socket right between the fairing. It's worked every time so far. I use Purolator filters from advance auto.
Old Jan 26, 2010 | 04:24 PM
Kuroshio's Avatar
Had trouble with mine on the first change. Possible some doped up mechanic used air tools to put it back on.
Ended up using this
Dunno if you have the clearance on your bike to use it tho
