Odometer accuracy with sprocket change
My Hurricane is 1 tooth down on the front sprocket and I have used a GPS to calculate the speedometer. I always figured the odometer would be inaccurate too, but I talked to another older Honda bike owner over the weekend and he said the odometer is still accurate. i have never worked on my speedometer and not sure it works, but I would think he is wrong. Can anyone clarify this for me concerning the odometer?
I understand about the speedometer, but in your case Timbuctwo, is your odometer(mileage) going to be 10% high as well?
My thoughts are the odometer is based on the speedometer, but the person I talked to said thats not the case. He said the speedometer could be incorrect and the odometer would still be corrrect.
on
I have an 18 front 44 rear and it's ratio is slightly less than stock.
Today I checked against the GPS I put on and I'm off by 2mph
Speedo reads 2mph more than actual............ I was expecting +2
over the speedo...........surprise there
So I'm guessing your one tooth down on the front puts
you off by 3 tor 5 mph .........my 2 cents
thanks for the input guys, but maybe you dont understand my question because its such a stupid one. LOL
i know my speedometer is off by 11% because I checked it with a GPS. Is my total mileage clock(odometer) off by 11% as well? The only reason i ask this is because i met another honda rider that said the odometer reading would still be accurate even if the speedometer was incorrect.
Dont think a speedo healer will work on the Hurricane, but I have one on my FZ. Easy to install and nice to have.
on
Correction
Hypothetically speaking
if the rear say had a 30 and the front had say a 15...........miles would surely clock up
at a slower rate because the countershaft would be turning slower even though you'd
be covering more ground............so yeah I'd say it would to be off too in fact I'd bet
Petes hat on it
Petes hat on it
I'm with you Bickle! If you are on stock gearing, your speedo will be a little off, showing maybe 2% more than actual speed, but the odometer will most likely be accurate, more or less. Change gearing, and the speedo will be more off, but the odometer will ALSO be off, but not as much as the speedo.
I have changed gearing, and I know my speedo is off, by 14-15% if I remember right, checked with GPS. Haven't checked the odo, but will. I'll check back to report my findings!
