Not enough coolant
Old 05-25-2014, 05:06 PM
hmm's Avatar
hmm
hmm is offline
Default Not enough coolant
Can anyone suggest why I only need about 2.25 litres of coolant after draining and flushing?
Is this why the bike heats up very quickly in traffic?
By the way, I can't remove the reserve tank (stripped nuts).
Thanks.
Old 05-25-2014, 05:41 PM
Kiwi born's Avatar
Now don't quote me as I'm not 100% sure on the factory levels but my F2 takes about the same to fill. So either mines broke too or your coolant volume is fine. If the bike heats up while sitting in traffic I would be looking at the fan. They seem to stuff out often enough to look there first. Run your bike, when she get hot you should hear the fan kick in. If not, first check to see if you've got power to it. If there's power then replace the sensor which you can get for under $15 on ebay postage included. If there's no power check fuse, if that's ok follow wire to find loose connection / break. I'm gusseing it's the sensor, if not that, then the fan motor itself.
Ohh yeah drill and re tap for the reserve tank.
Hopefully this tid bit of info can help you out
Cheers
KB
Old 05-25-2014, 05:43 PM
hawkwind's Avatar
There may be air in the system, you'll need to run the bike with the cap off until all the air is bled out, topping up the coolant as necessary.
Air in the system will cause overheating problems.
Old 05-25-2014, 05:45 PM
Kiwi born's Avatar
Sorry, to check your fan, put it to a direct power supply. It should buzz into life. If it IS working then go get a sensor. If it not going skip the sensor and get the fan. Install and if no go then yep you need the sensor also.
Old 05-25-2014, 05:47 PM
Kiwi born's Avatar
Hawk wind has a bloody good point. I assumed you already bled the system. So if you haven't congrats you just saved some money
Old 05-25-2014, 05:58 PM
hawkwind's Avatar
Haynes manual says coolant capacity for 1000 is 3 liters.
Kiwi capacity for the 600 is only 2 liters, so you don't need to worry
Old 05-25-2014, 09:32 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
There's still some liquid trapped in the system. You'll never get all of it out.
That's why whenever I do a coolant flush and I know there's just water left I check the total coolant capacity in my manual and add 100% pure antifreeze equal to 1/2 of the total capacity. Then I add distilled water until it is full. The final result is a 50-50 mix.
Old 05-26-2014, 03:55 PM
hmm's Avatar
hmm
hmm is offline
Thanks folks.
The radiator fan switch stopped working a while ago so I installed a manual switch until I could get a new one. Then suddenly it started working automatically again and has been working ever since.
When I refilled with coolant I followed the Haynes instructions, blipped the throttle up to 5-6000 rpm a few times and filled to the neck.
Also fitted a new thermostat recently which may have a lower opening temperature.
If there's always some fluid left, I guess it's OK.
So I'll stop worrying.
Old 05-26-2014, 07:00 PM
hawkwind's Avatar
Don't forget you need to let it run up to temperature, takes about 5-10 mins to get rid of all the air in the system.
Old 05-26-2014, 09:07 PM
Sprock's Avatar
Good subject matter and a memory jogger !
I remember I had a post in here way back on a thermo switch cross reference with
some of those having a lower trip temp. Might have been a Subaru switch - hmm
must hunt it down.
edit:
Correction it was a Nissan Pulsar
Here it is and of course needless to say my 93 commuter still has a manual switch
5 years later guess I lost my old to do list
https://cbrforum.com/forum/cbr-1000f...2-003-a-87951/
http://www.autozone.com/autozone/par...entifier=31701
Quick Reply: Not enough coolant
