Nagging Problem Solved.
Old Apr 19, 2010 | 05:49 AM
Equaliser's Avatar
Default Nagging Problem Solved.
Hi Guys,
Some time ago I asked if anyone could give me advice on a fuel problem I was having. What the problem was, that the morning after a decent ride the bike would starve of fuel after a couple of minutes running. To get my bike going again, I would have to remove the seat, remove the fuel line from the Petcock, and allow an air blockage to clear. At first I thought it was a kinked breather hose, but was unable to find any. I was getting so pissed of with this annoyance, that I was even prepared to remove the carbi and replace all the breather hoses.
Then just out of idle curiousity, I removed the Petcock assembly from the tank, and stripped it down. I found several microscopic holes in the rubber diaphragm. I sent away for a rebuild kit costing a whole $15, installed the new diaphragm, and have not had a problem since.....FIXED!
Happy Days!
Old Apr 19, 2010 | 11:15 AM
kilgoretrout's Avatar
Administrator - Retired
*and yer I do understand that there can be other causes for this type of issue *
Yeah... I half expected to hear "I solved my nagging problem by kicking that bish to the curb!"
Glad it was just a leaky petcock.
Happy to hear it's sorted out, man.
Old Apr 19, 2010 | 11:25 AM
hawkwind's Avatar
^^^^ Yeah , I was half expecting , nagging problem solved ..... Divorced the wife
Glad you solved the problem Equaliser and 15 bucks is a lot cheaper than my solution
Old Apr 19, 2010 | 11:40 AM
Sprock's Avatar
umm I see ya all got there before me .... I was going with ear plugs for me duct tape for her .......
But on the actual subject ... I wonder if carb cleaner does that to the rubber diaphragm ? (bit like wd on an oring chain ) or is it just an old used up
piece of rubber that's to blame here !
Old Apr 19, 2010 | 08:02 PM
Equaliser's Avatar
I once used one of those 'carbi / jet cleaning' fuel additives many months ago, maybe it had some effect on rubber parts....who knows.
Old Apr 19, 2010 | 08:57 PM
I suppose it may not have helped... but I don't know, probably just old and needed replaced.
Old Apr 26, 2010 | 04:10 PM
HenryM's Avatar
I'd go with the 'it was just old theory' especially where you live Eq..... al that heat.
As for the nagging problem, divorce may be a bit radical hawk but it's along the right lines if you can't solve it. I use the Dutch oven technique myself. Just wait for to go to sleep, head under the covers and wuff.....
Old Aug 2, 2011 | 05:14 AM
richbo's Avatar
i hav the same problem, butt my petcock is new and it still stalls out after being warmed up or im at a stopliight for a minute or two
bluerrchik
Mar 25, 2010 10:25 PM
woo545
Jul 17, 2008 05:13 AM
eylauraa
Jul 17, 2007 05:49 AM
Trips
Nov 26, 2006 01:45 AM
hwnf4i
Jul 29, 2006 09:18 PM
