More Cane problem
Old Sep 7, 2008 | 10:32 AM
87hcane's Avatar
Default More Cane problem
well i pulled her out this morning after working on it late last night.
she wont start again.
lights come it cranks but no fire. I pulled the plugs they are champion 8809. 3 of the 4 have rust centers to them (I forget what that middle part is called.)
So today I am going to change the oil and filter (was planning on it anyway) but what i was wondering was do u guys ever use the champion plugs or just ngk.
we always use the champions at the shop for lawnmowers and then ngk for the 2 cycle echos that we sell but i have always ran the ngk plugs.
the good is i can either get them thru one of our reps or i can order them off ebay.
or i can go to walmart and get the champion powersport plugs? do u guys think there is a big difference between the two plugs?
Old Sep 7, 2008 | 10:56 AM
Shadow's Avatar
Default RE: More Cane problem
Clean the plugs, charge the battery for 12-14 hours, then try again. CBR's will NOT fire if the battery is even a little flat - they'll turn over but not fire. If that doesn't work, maybe your kill switch or other problem - all four plugs won't fail at once. Check the plug gaps at .8-.9mm
If the plugs are wet after trying, it's probably an electrical fault.........[X(]
Old Sep 7, 2008 | 11:15 AM
87hcane's Avatar
the plugs werent wet. They are seriously the worst plugs i have ever saw in my life. 3 of the 4 have rusty looking centers.
Old Sep 7, 2008 | 11:24 AM
Shadow's Avatar
Replace them NGK DPR9EA9 is what I use. Try again, and if they're still not wet you have a fuel delivery problem, ie the fuel isn't getting to the cylinders.....[X(]
Old Sep 7, 2008 | 02:22 PM
bruiserc's Avatar
I use NGK plugs. I get them from the Honda dealership. Not that expensive.
Old Sep 7, 2008 | 02:53 PM
bruiserc's Avatar
Just got off ebay and found a honda hurricane 1000 service manual with starting bid at .99. If you decide to keep your bike I highly recommend getting one. Has all you need to know about this bike. Type in 87-88 cbr to find it on ebay.
Old Sep 7, 2008 | 07:03 PM
87hcane's Avatar
im going to keep just really wanted to ride it bad this year but i didnt expect to so winter project it is.
Old Sep 7, 2008 | 07:28 PM
Shadow's Avatar
If you've got a mailbox that'll take 11 Mb, I'll mail you a service manual, Bruiser, or go to
WORKS MANUAL
EARLY CBR600 & 1000f
Old Sep 7, 2008 | 11:52 PM
87hcane's Avatar
the plugs were getting fuel they were wet when i took them out they just look like ****. also i just ordered 4 new ngk plugs they should be here wed hopefully then i am going to put them in see if it will start and change the oil and filter and check the air filter.
I just also charged the battery with my tender again today.
Old Sep 8, 2008 | 01:47 PM
Bassman's Avatar
My experience with Champions in a CB 500F was that the recommended Champion was too cold. It ran at first but slowly laoded up until I got a miss fire at high RPM. The heat ranges between plug manf. are not a direct cross over.
I just put in a set of Irridium NGK's in the 1000 and it runs like new again. Better than the std. NGK's.
I got them from www.sparkplugs.comfor about $10 each delivered.
