Leaning old bike
Old 05-16-2006, 04:33 PM
R1000's Avatar
Default RE: Leaning old bike
Looking foward to see pics when you pull up the CBR on its rear banana, be careful though.
Old 05-16-2006, 09:03 PM
Rx7man's Avatar
if there were someone to take pics I'd show you some of mine.. clutch will have to be done soon though
Old 05-17-2006, 01:32 AM
slowpoke's Avatar
ORIGINAL: R1000
I have adjusted the float levels to 9 mm, but saw in another reference that they should be set to 13 mm. Any one have exeperienced this and know for sure what the optimal float level should be?
I set my 1990 to the books 9mm, but a local shop mechanic said to adjust them to 7mm for Denver (above 5,000 feet).
Old 05-17-2006, 05:43 AM
R1000's Avatar
Taking the risk being called stupid, I'm curious about this. At high altitudes the air is less dense. To keep the same air/fuel ratio at high altitudes would then mean less fuel to me. 7 mm float level compared to 9 mm would give more fuel since the floater device will move up 2 mm. The float level measuremet is taken from the float device to the upper joint of the float chamber. I might very well be wrong but that is how I understand it. If you have the possibility to double-check with the Denver mechanic, please come back and report his point of view.
I have appended a blurry picture from the Honda manual that reads 13,7 mm float level, while the Haynes manual specify 9 mm if I remember right. I use the same setting as you, 9 mm,
Old 05-17-2006, 08:50 AM
Trips's Avatar
ORIGINAL: rhino94
Please explain the word bargeass to a Swede.
CanĀ“t find it in wikipedia
Bargeass means I have an *** as big as a Barge. :P
Here is a pic of how to scrape a CBR1000F I came across.
Old 05-17-2006, 09:35 AM
R1000's Avatar
The guy would be lucky if he makes that turn, there seems to be a lot of air between the rear tyre and the tarmac. The silencer is scratching ground and lifting the rear. If thats whats needed, IĀ“ll pass...
Old 05-17-2006, 10:19 AM
OldFatGuy's Avatar
ORIGINAL: rhino94
I wached a movie on the Swedish www.sporthoj.com where a goldwing was followed and filmed by another bike.
The goldwing scraped the bags in every curve and the sportbike following had a hard time keeping up.
Thats the spirit!
Got a link to the video? I'd like to see it. I looked at the site and couldn't find it...
My swedish is kinda rusty - haven't spoken it since 1612.
Old 05-17-2006, 10:34 AM
kilgoretrout's Avatar
Administrator - Retired
oh my god!! that pic is insane. There is little chance of that guy making the turn. There is a good reason he has a cage on that bike.
Old 05-17-2006, 11:38 AM
Old 05-17-2006, 02:50 PM
Mother of devine! That's insane.
Quick Reply: Leaning old bike
