leaky bowls - what sealant you use ?
on
Did you read the whole thing TBT ? Like Permatex #1 it's a sealant more than an
actual gasket maker and it specifically states diesel fuel, gasoline, kerosene, jet fuel.
but maybe not that ethanol stuff you love so much lol
I have not used it yet as I went with the Permatex Form A Gasket Sealant #1 ----
which cures hard and has sealed up the bowls tighter that a gnats azzz
As I said I refuse to spend nearly 100 bucks on 4 new gaskets as it would be
like buying 4 rubber bands for 25 bucks a piece - ya just dont need to do it ! simple
Just put 425 miles on the 93 with the "new" carbs and jet kits - no leaks ! and
there won't be until I crack them open again in maybe 2 years from now
The rejetted carbs for the 1990 - I will try the PLS 2 on and I expect it too will work
just fine as it's not silicone based
Manufacturers Link
Manufacturers Link
· Lead-free, non-hardening, non-toxic, opaque gray paste
· Adheres readily to iron, stainless steel, aluminum, monel, plastics, and synthetic rubber compounds
· For use with dilute acids, aliphatic solvents, ammonia, dilute caustic alkali, chlorine, diesel fuel, gasoline, kerosene, jet fuel, LPG, natural gas, petroleum solvents, heating oils, hydraulic oils, mineral oils, refrigerants and steam
· Not for oxygen
· Brush on to seal pipe joints, plugs, screwed fittings and gasketed connections in steam systems, refineries, gas service, refrigeration systems and chemical plants
· Temperature Range: -100°F to 600°F (-74°C to 318°C)
· Pressure Range: To 10,000 psi sealing liquids; to 3,000 psi sealing gases
· UL® and ULC® Classified. CSA® approved
on
1) Yup pulled them out put a bead of #1 sealant in the "U" put gasket back
in and gave her a skin coat over the top , torqued right down and let
cure 24 hours until residue on outside went from dark reddish brown
to a nice light maple color.
2) Happy to oblige
2) Happy to oblige
