Leaking fuel when on the side stand
Old Dec 25, 2009 | 07:08 PM
tomttt's Avatar
Default Leaking fuel when on the side stand
Guys, I need some help. Last week, on the way to a "toy ride" it happened again. When I put the bike on the side stand fuel leaks from the carbs, at least it seems like it leaks from the carbs. Tank was only 3/4 full and not near the filler opening.
The petcock is new and turning it off does not seem to have any effect.
Have any of u guys had this happen to U?
I intend to pull the plastic and see if I can see where it is coming from, problem is that it doesn't happen every time.
Any Help is truly appreciated!
Old Dec 25, 2009 | 10:36 PM
Shadow's Avatar
Check the rubber petrol hose going into the tank(and down to the carbs)- they sometimes perish and it smells bad - mine did.....fit some cable ties around it, job done.
Could also be the O rings in the carbs (much more work)
Old Dec 26, 2009 | 12:01 AM
Az1kF's Avatar
My guess is it's your floats, at least one of them is sticking & there you have the overflow leak.
Old Dec 26, 2009 | 08:07 AM
malbojah's Avatar
Being a 96 with a vacuum petcock, the gas flow should stop once the engine is off
Old Dec 26, 2009 | 09:29 AM
Yes, that's probably true. However, if more than one float valve is not sealing correctly, then there is nothing to prevent the flow of fuel from one carburetor to another, over filling the lowest one while on the side stand. It is possible to siphon from one carb to another by way of the "T" fitting between the carbs.
Old Dec 26, 2009 | 10:46 AM
tomttt's Avatar
I suspect it is one or more float, the symptoms indicate that rather than the petcock. Thanks for ur replies.
Has anyone R&R'ed the seats in these carbs?
Thanks again
Old Dec 26, 2009 | 06:06 PM
TimBucTwo's Avatar
Yep! And another problem could be that fuel is passing down through the rings and into the oil.
Tomttt, you should smell the oil dip stick to see if it smalls like gas. If so you also need to do an oil change. I depends on how much fuel is actually passing, if any, to thin the oil.
I had a sticky float a few years ago and all I did was run a tank full with carb/injection cleaner and it removed the crap that was plating out between the needle and seat.
Old Dec 26, 2009 | 06:14 PM
Az1kF's Avatar
Could this be a job for that Seafoam stuff for those of you who have used it before?
Old Dec 26, 2009 | 06:27 PM
TimBucTwo's Avatar
Seafoam works great but I don't know if it will remove heavy deposits as quickly as the injection cleaners.
I mentioned doing this because it may be the quick fix if you are lucky. There may be a hunk of crap like sand or something else that may not dissolve and you may need to take them apart. If you are lucky, the cleaner may be all you need. It doesn't hurt to try.
