Inspecting CBR1000F
I assumed he meant 'Marvel's Mystery Oil', something that's been around in the States practically forever. Not sure if it's legitimate science or hocus-pocus, but lots of folks swear by it.
Larry
Larry
on
yep cleaned all my motors of carbon lickety split
especially Volvo
add a quart to an oil change
ie 3 PTs oil 1 PTs Marvel ruby
magic run for 4 hours or 500 miles depending how fast you ride. fn. lol.
all is **** shining clean
you could eat you din din's of it.
I'll venture no more
especially Volvo
![Big Grin](https://cbrforum.com/forum/images/smilies/biggrin.gif)
I wouldn't put the oil in the gas tank. But besides putting the Mystery oil into the crankcase, you can also run a cap-full (about an ounce) in each intake. You do this by putting a hose on one sync nipple of the intake, and the other end of the hose in a cap-full of Marvel Mystery oil. Run the engine until the engine vacuum empties the cap. Then do it for each intake individually, and the cylinder head and valves get clean.
"Burt Pierce was the founder of the Marvel Oil Company in 1923.
After World War I, vehicles encountered carburetor problems. As a result Mr. Pierce formulated a blend of chemicals and petroleum to clean and maintain clogged jets. It proved beneficial for engines by creating a top ring seal producing higher compression, preventing blow-by on power strokes, resulting in more power.
Mystery Oil was also found to improve gas mileage when used as a fuel additive.[citation needed]
Since the use of Ethanol in gasoline, which breaks down and gels in gas tanks, fuel injectors and carburetor jets, adding Marvels will help slow and possibly eliminate the gelling of ethanol gas in Fuel Injected and Carburetor engines; making it a very suitable winterizing solvent."
From Slick 50 and other engine oil additives - The Skeptic's Dictionary - Skepdic.com
"Stuff like Bardahl, Rislone and Marvel Mystery Oil claim they can make your engine run quieter and smoother, and reduce oil burning. These are products which contain solvents or detergents such as kerosene, naphthalene, xylene, acetone or isopropanol."
My father used to swear by the stuff for cleaning valves on older engines.
