Inner handle bar weight.
If you mean the outer end of the handle bar, it's just to loosen the phillips screw at the end a couple of turns and pull it out, or adjust it into position again if it had been hit.
part #7 is held in place by part #10. It's just a rubber bushing that hold the weight in place. The easiest way to take it out I think would be to remove the bar end weight, screw in a long bolt, then slide hammer the balancer out. It might require some sort of penetrating oil to loosen up the rubber bushing.
ORIGINAL: malbojah
The bar weight reduces vibration in the handle bar. Helps with the tingles.
The rubber parts friction holds it in.
EDIT ADD: At $161 for a new handelbar, if you can't get the inner part out, maybe start thinking about Heli Bars for a few bucks more. I just wanted to throw that in there.
[IMG]local://upfiles/8473/FCFF29CB967C4FCCA25551475B625A0D.jpg[/IMG]
Abacus, did you ever get this fixed, and if so what did you do. I accidentily (sp) dropped my bike this morning [:@] and the bar end snapped off along with the end of the inner handle bar weight. Just wanting to know what I need to do to fix it and how much it's going to cost me.
