i need HELP!
#21
#22
#23
#24
OK so it's a MK1, I didn't see where the year was mentioned. SO with that, you need fuel and spark to run. These bikes were lean from the factory and won't start without the choke as mentioned. The MK1 also has a fuel pump that can fail, so it may not be getting fuel.
If it's not a choke issue, the quickest things to check up front is,
(1) lift the tank and pull a plug. With the plug touching the head, crank it over and check for spark.
(2) pull the fuel line and see if fuel is flowing.
Do those things first. You must know the results of Choke and/or 1 & 2 before moving on.
