Hurricane rebuild
Old Mar 23, 2013 | 12:00 AM
  #51
AMSOIL929's Avatar
I just joined the forum and unfortunately cannot look at the pictures (I imagine I do not have the rights yet). I too am rebuilding a hurricane. I have a 1990. Hopefully I can see the pictures soon!
Old Mar 23, 2013 | 02:24 PM
  #52
wheelnut's Avatar
Welcome Crew
cheers hawkwind, will try and make a list of what i need, it will never amount to the price of shoes and handbags will just add the wifes a diamond and you can never have enough shoes .
then lets go shopping,
and amsoil929 i think you should be able to see the pictures once youve signed in.
Old Mar 25, 2013 | 08:27 AM
  #53
wheelnut's Avatar
Welcome Crew
only got out to the shed for a short while on sunday .
so i have packed up the shock its off for a rebuild, had a bit of trouble finding
someone to rebuild this showa unit, so will let you know how it goes.
Made a list of the bits i may need, i say may because i have aquired a new(secondhand) relay and connecting rod and have been told it is in really good condition.
so heres the list, i havent put part no`s on as everywhere seems to have their own numbers.
Top shock mount. 1. inner bush,outer bush,dust caps,bolt,dust seals
Relay arm 2. all 3 collars/sleeves, 3 bolts, 3 nuts and the lower shock
mounting bush.
connecting rod 3. collar/sleeve, nut and bolt
i had a look at a couple of places an cmsnl were the cheaper at £114.16 including shipping.
any one that can help with my shopping would be appreciated
Old Mar 25, 2013 | 12:49 PM
  #54
Sprock's Avatar
I did these at one point too about 1 1/2 ago those bushings are a complete f'ing
bear - I basically drove the center collar and rubber out then carefully cut a groove in
the outer sleeve and collapsed it in on itself and removed - putting a new one in was easier
with a bench vise and some appropriately sized sockets to press the new bushing in.
Here's most of the parts you seek
Did you send that shock to Jaws, Moto Pro or Reactive Suspension ?
Old Mar 26, 2013 | 02:59 AM
  #55
wheelnut's Avatar
Welcome Crew
funny you should say about jaws, i have been waiting for an email from them, and it arrived after id sent it off, so i have used firefox racing, like you say i had to do the same with my bush it were a pig, thanks for the link, when the new (secondhand linkage) gets here i can see what im going to need.
Old Mar 26, 2013 | 04:24 PM
  #56
Sprock's Avatar
Anytime
Look forward to seeing how the rebuilt Showa comes out !
Take it they'll be putting an upgraded spring on it ? if not you should ask
Old Mar 27, 2013 | 05:17 AM
  #57
wheelnut's Avatar
Welcome Crew
i would really like to upgrade the spring, but me credit card has had a bit of a beating , the shock should be with them today so i may call and see if they can do me a deal, you dont know if you dont ask , im off out in shed tonight for a few hours and then i have some time off work, so im hoping to get a bit more done,
Old Mar 27, 2013 | 06:06 AM
  #58
hawkwind's Avatar
If you're going to do it (the spring), I'd do it now, or it'll be one of those things that'll bug you forever and cost more if you get it at a later date.
These days I think of things in terms of tanks of petrol, anything £70 or less, it's just like buying a tank of petrol for the car
Old Mar 28, 2013 | 08:37 AM
  #59
wheelnut's Avatar
Welcome Crew
spoke to firefox today and he dosent stock that spring and it would take a while to get it, so he has checked my spring and its good, so for now im gonna make do, the good lady has hinted that maybe for christmas and birthday i can get a new shocker, so that would tie in nicely for next time i regrease the rear suspension,
got back out to the shed last night and have rubbed down the swinger ready for its rebuild and painting, then i had a look at the rear calliper, i knew it wasnt working well when i got the bike as the rust on the rear disc was not uniform, when i had a look last night i can see why, one piston was siezed up. i cleaned up both pistons and then used my home made retractor tool (see pic) and pushed them back in, then pupmed them out and cleaned them right off, one piston at a time (using something to hold the other piston in), their working ok now so i can put new pads and pins in when i get the back end in.
Attached Thumbnails Hurricane rebuild-photo0019.jpg   Hurricane rebuild-photo0017.jpg   Hurricane rebuild-photo0018.jpg
Old Mar 28, 2013 | 05:37 PM
  #60
Sebastionbear1's Avatar
Great work Wheelnut,
I'm going to copy your retractor for future use
Cheers, SB
