Hey all! Oil change time. What should I use?
Old Aug 15, 2010 | 01:19 PM
kilgoretrout's Avatar
Administrator - Retired
I run Rotella T or Mobil 1. Rotella is about $11/gal for standard oil and $21/gal for synthetic.
Mobil 1 is on sale for $21/5qts at wally world right now. Great oil, just remember to get the 10W40 or higher. The lower wts are "energy conserving" and you don't want that as it contains metal additives that can cause clutch slip.
Old Aug 15, 2010 | 02:03 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Default +1 Rotella T synthetic
I have been using Synthetic in my bike since I know it has been available. I like the Rotella T. Also use the search engine on here there are lots of threads on oil....
Old Aug 15, 2010 | 02:28 PM
I wouldn't worry about buying a special moto specific Mobil 1. The regular stuff will be fine. Just get a viscosity that's in the recommended range for your temps, and don't get the energy conserving stuff. (it will say so right on the bottle....inside the api "starburst")
I also run purolator filters from advance auto.
Old Aug 15, 2010 | 02:33 PM
I run the K&N Oil Filter and change my oil every 3000-3500 miles...
Old Aug 15, 2010 | 07:47 PM
Changing at 3k isn't necessary, but that's up to you.
On the oil ... I'm running Rotella, too. Great oil for sure. I mentioned the Mobil 1 because it's also really great oil and it's cheaper than rotella synth right now at wally world ($3 cheaper and comes with an extra quart!)
If I didn't have 4gals of rotella right now, I'd be stocking up on the mobil 1.
Jared (thrdgenlxi) has put almost 200,000 miles on his F4i on mobil 1 and purolator filters. He changes every 5k miles.
The K&N is a rebranded hi-flo filter, by the way. It's an ok filter, I guess, but 2X the price of the hi-flo where I'm at. Also, I've heard a lot of oil people say that the purolator pureone is better than the K&N/hi-flo. (and also half the price and available at all advance auto parts stores)
If you like the little nut on the end, that's cool. I use the longer pureone filter for a little more filter instead and just use a filter socket.
From calsci...
Pureone PL14610:
This is how an oil filter should be made. The anti-drainback valve is double the thickness of any other here, and obviously seals very well. The media is the best available, and there's a lot of it. The bypass valve is made from a laser-cut piece of stainless steel, and just can't bind or jam.
Hi-flo HF138: An average filter at a competitive price.
K&N 138:
Made by Hi Flo. Average filter with a $6 nut welded onto the end cap.
Old Aug 16, 2010 | 03:22 PM
dietDrThunder's Avatar
What ^^ he said, 100%.
Old Aug 17, 2010 | 04:20 AM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
My fathers advice....
Use cheap oil but change it often (3000k's), it is very cheap insurance.
Me, i use 20/50 mineral oil change every 3000k's including filter.
Keep the oil fresh!
Aussie Johnno
nemesis36
Oct 29, 2008 11:34 AM
SchiraF4I
Feb 24, 2007 03:24 PM
bglover
Oct 1, 2006 05:02 PM
outsider8
Sep 15, 2006 12:24 AM
jasonb
Aug 2, 2006 08:04 PM
