HELP:What is this part????
Old May 22, 2009 | 05:43 PM
Imo000's Avatar
Default HELP:What is this part????
I think they go somewhere between the lower fairing and the frame but for the life of me I can't figure it out. They were removed when I bought the bike. I think they are some sort of an air deflector. They are each marked with an R and an L too. Any help would be greatly appreciated.
Attached Thumbnails HELP:What is this part????-10.jpg   HELP:What is this part????-11.jpg   HELP:What is this part????-12.jpg
Old May 22, 2009 | 06:01 PM
hawkwind's Avatar
What model or year bike do you have?
Old May 22, 2009 | 06:45 PM
Imo000's Avatar
'87 Hurricane 1000 or CBR 1000F for outsides of North America.
Old May 23, 2009 | 02:27 AM
Shadow's Avatar
This may help ?
http://www.mrcycles.com/fiche_sectio...1987&fveh=3018
Old May 23, 2009 | 07:06 AM
malbojah's Avatar
Originally Posted by Shadow
#20 and 21
OR
on the 93+ there are plastic dampers that sit between the cylinder head and the frame and it looks like them.
Old May 23, 2009 | 07:12 AM
Imo000's Avatar
Shadow, Thanks fo rht elink but I laready looked at the same diagram in the repair manual. #19 & 20 looked sort of like it but they are different. Thye are both made of rubber.
Old May 23, 2009 | 09:44 AM
Shadow's Avatar
I have similar parts which fit between my fairing and the engine just below the fuse and coolant covers. I think they're air deflectors to improve flow through the radiator (I can't think of any other reason for them being there.........
Maybe some of the early model owners can help here......
Old May 23, 2009 | 10:44 AM
TimBucTwo's Avatar
They are rubber heat guards. They stop the hot air coming off of the radiator from passing up under the tank and saddle. On my 1994 there is one piece that goes all the way across and down the sides. It is bolted in place under the spark coils and I think at the sides. When I adjust the valves I think I have to remove it to get the valve cover off, or at lease make the adjustments.
Old May 23, 2009 | 11:22 AM
Imo000's Avatar
yes, yes that's what they must be cause there is a heck of a lot of hot air coming from the petcock/side cover area.
I've tried to installe them when I had the engie apart but couldn't figure it out. I wish I could find a picture of someone's bike that shows this in place.
Old May 23, 2009 | 12:11 PM
Shadow's Avatar
Mine's a 90 model but I have my fairings and tank off ATM - would you like some pics - probably similar to yours ?
