Head porting or not - ****update with dyno graph****
RE: Head porting or not
And hereis abefore pic showing that the ports are veryunsmooth stock.The engine will also recieve new cams to improve mid and top range, and an Akrapovic unrestricted 4-2-1 system. In case it pulls well enough up to 200 km/h, i.e. the concept works OK, it will also be provided with RAM air to handle wind resistance at higher speeds. It is possible to use the air ducts from newer FI-models and gaing another 5 to 10 hp at high speeds. That mod requires to put the float chambers under pressure from the air box, and possibly also an electrical and regulated fuel pump.
[IMG]local://upfiles/4562/5F3C1AF0891D44FCA97815A05C5FDF74.jpg[/IMG]
my cbr1000f has its head cleaned out n machined exhaust ports by a previous owner,i have not long fitted larger bore stainless downpipes and end cans(i like twin cans) and its made an amazing difference to the power,it always felt like it had a cold b4,obviously the carbs need a sort as well but just minor adjustments.
only problem i have now is the fairing lowers wont close up and i get the occasional melting plastic smell.
so if u can afford it,definatly an improvement for little money and quite a buzz munching the newer bikes out there with a bike that looks standard /original
Finally, I got the chance todayto test theBird with the ported head and other camshafts. I only runned for about 15 minutes before I returned and changed oil. The initial impression is that I have got a completely new bike, the throttle response is far better and when I launched like usual the bike did a long wheelie which it have never done during the same conditions. Will test more the coming weekend but there is no doubt that the porting and other camshafts have done great things to the engine.
Do the heads need improvement?
From automotive experience on automotive engines, if you just port the heads you will do nothing and will probably not run good. Change one thing, everything else has to support that mod. Port your heads then you need: Higher Flowing Carb, Intake, Exhaust, Camshaft for those components, and the powerband will probably shift to higher RPMs.
But hey, if the heads are the only bottle neck, porting will improve guarenteed.
Its just like the K&N filter, by installing, people unconciously think it increases valve lift, ports out your intake runners while increasing compression. LOL
ORIGINAL: WhiteHawk
ORIGINAL: mikekop
Sounds Great! Are you gonna dyno it? Would be interesting to hear what the porting by Dr: Bike alone did for power without the other camshafts.
It is all done, but the bike is not dynoed yet. Thefeeling in thebackreports good things have happenedto the engine though. It is by fareasier to feel performance increase on a bike than a car. The amount of front lift and how easy that come or not gives good indications of the power level and delivery. Also if the rear wheel spins or the bike grips and leaves ground easily tells a lot about how the torque band is. To late and intense power will cause lost grip in the rear, if the power builds early and evenly the weight is better transferred to the rear and the bike is much easier to control..
