GPS on the bike?
RE: GPS on the bike?
Yes,they offer a 5 day free trial, so why not ?
And yes I have a bluetooth dongle...........
I thought of fitting the power outlet up front by the fuses, but I'm not keen to start drilling holes in the Old Girl.......Any suggestions ? Maybe, sideways through the fuse panel, so you can't see the outlet (facing the forks).....?
This is how I did the 12V socket:
12V socket from "Biltema" (swedish lowprice store, mainly carparts) 25 SEK ~ 3 euro
I removed the square flat mounting piece, connected cables to the socket with 12V connectors with shrink plastic + melting glue, also supplied by Biltema. Then I put over a pretty big shrink plastic tube over the socket from the connector side, shrinked it, and sealed the end with electrical tape. I then tied the socket around the ignition key socket with plastic tie ribbons (don't know the english word for those), and connected the + cable to the 10A fuse socket for parking/rear lights, and the - cable to ground ( I had a earthing cable pre-installed since I have converted the low beam lights to direct feed from the battery via relay, used that). I guess total amount money for all pieces was less the 75 SEK (8 euro).
I was really confused where to put it, was thinking same as you, side panels, but did'nt want to drill holes either. Then I realized that ideal would be that the 12V socket followed the turning of the handlebars, and the ignition key socket was already doing that, sooo...
I think it turned out allright.
[IMG]local://upfiles/6357/37434D39BC994EA3A0E5B0EE04A7C1C2.jpg[/IMG]
[IMG]local://upfiles/6357/4C624EA418264A62A3BF98B63ABA886A.jpg[/IMG]
[IMG]local://upfiles/6357/C3022B8D89934EC99CA49F4DDF7BEEE5.jpg[/IMG]
I been using my N95 with tomtom on it in my tankbag for a while, and before that i was using my Pda same software, faultless, comes in handy with the mobile camera updates aswell.. but i just bought a garmin satnav cheap , rigged a 12v waterproof socket same asmikekopbut i removed thefixingplate in the fusebox area, connected to the ignition and i just plug in the power supply and screw the fuse cover back down, stick the satnav to the windshield and off i go,it aint waterproof but it stays dry under there and has worked well so far
Here's the link to Navicore for map downloads - I have been having problems, but will sort it out.....
https://shop.wayfinder.com/category_show.php?catid=15
