RE: Getting ready to paint
I'm going to try and find a few more pictures I took of the rebuilding of the tabs. Basically what I did was try to mirror one side to the other. My left side was all jacked up and the right side was just fine. So I had to replicate everything from right to left. Some things are not the same, just be warned. Then that I would do when I knew what it should look like it create some sort of blank that I would mold the fiberglass around. (This is where pictures would be really helpful.) So on the upper left front fairing I needed to rebuild the mount that attached to the frame. This mount is indented behind the fairing. So what I did was cut a block of wood the same size and then layer fiberglass over it to give it the same shape while also attaching it in the correct place on the fairing itself.
I need some pictures. I'll get some and see if I can finish this up. MDFF |
MD, too bad you didn't have someone nearby with an 1000F, then you could have taken molds of the tabs and made them more easily.
Alright alright, I'm sad enough about moving back to MD. You don't have to rub it in. :(;)
MDFF |
What would you recommend as far as a fiberglass kit...could it be purchased at an Autozone, Napa, or Advance Auto? They have a fiberglass repair kit..would that work? My problem is the two rear tabs on the upper cowl (the two [one on each side] hex head bolts that connect CLOSEST to you when your on the bike) are broken completely off and the lower cowl isn't really secure when I'm riding or going over any bumps.
Would I just be able to use something like a thin piece of cardboard, then put the fiberglass stuff over it? |
2 Attachment(s)
I used a fiberglass repair kit from Walmart. I'm a little heavy handed with the hardner so I had to get more, but I didn't use anything close to the whole blanket of glass itself. Any kit that gets the job done is a good one, the one I got happened to be for boats but I figure its a good thing because it is water resistant.
When I did some other things on the bike like the rear cowl tabs I used a paint stick with platic wrap over it to keep the resin and glass from sticking, that worked pretty well. I also tried aluminum foil and that stuck more then plastic wrap. Just cover whatever you are using as a "mold" so you don't have to cut it off or break when you just fixed. I don't have any progress pics of the fix for the front cowl but here are some progress pics of the rear cowl. Looks different now that it is final primed. Rough and just cut in half Attachment 85712 Cleaned up with dremmel Attachment 85713 *EDIT* Also, remember that resin by itself is very brittle thats why it is combined with the glass. Never use resin by itself. However, paining over fiberglass will look bad, so cover it up with a good layer of resin and then sand it down to where you need it. That will give you a nice smooth finish. MDFF |
Nice job. My bike wasn't dropped, but both tabs on the rear cowl were cracked off at the bolt hole and where it connects to the main piece. Luckily, the pieces were still held there by the bolts. I used epoxy to glue them back together. I bet if everyone with a 1000F checked them, they would find that they're cracked from vibration.
Hey, I just wanted to give yall an update. I got everything final primed and I'm in the process of wet sanding the primer to get rid of the orange peel. I ordered another tip (#2) for my HVLP gun as the one for the primer (#3) is NOT going to cut it for the color. Hopefully I should have the primary color (black) shot this weekend. I'll make sure I take some pics during the painting this time.
MDFF |
Base coat!!!!
10 Attachment(s)
Alrighty, here are some prelim pics from the base coat (black) painting I did today. Enjoy!
My paint "booth" from the outside: Attachment 85605 All kinds of parts drying between coats: Attachment 85606 Attachment 85607 Attachment 85608 Attachment 85609 Attachment 85610 Attachment 85611 Attachment 85612 This is my favorite: Attachment 85613 This will teach me to paint with long sleeves on: Attachment 85614 Let me know what you think!! Sliver accent graphic is going on tomorrow. Then color sanding and clear to come later after I get back from my trip to Denver. MDFF |
RE: Base coat!!!!
Great job, it seems to turn out real fine !
I renovated an old car many years ago and a lot of small parts were hand-sprayed glossy black. It didn’t take much practice until I managed to always get a perfect result. This spring I was to spray-paint parts on the Hurricane, and knew that it should be easy. To my surprise it was now impossible not to get a raw finish or the opposite, to much paint. It was just to leave the parts to a paint shop; I had lost the technique to get a perfect surface. I guess the knowledge is kind of a skill that doesn’t last forever, or it’s just the vision degrading over the year. |
RE: Base coat!!!!
5 Attachment(s)
Ok, I just had to post some more. I fitted up the pannels so I could mask off for the second color and snaped some pics.
Attachment 85598 Attachment 85599 Attachment 85600 Attachment 85601 Attachment 85602 MDFF |
