Front brake swap
Front brake swap
Has anyone done a front brake conversion on a hurricane? I need new front rotors and was wondering if I could use a rr or some other better cbr brake system. If it would bolt right up. I couldn't find any info on this site or the web so, I was just wondering what you guys had to say. My Hurricane is a '87.
RE: Front brake swap
You can check the 98 brakes, but I don't think they'll fit.
You could also look at www.mrcycles.com, and look at the exploded parts views for all bikes, all makes and models, and see what works.........
Good luck - you may have to find a front end with 42mm fork tubes, and the correct steering head size, and fit the whole thing.......
Lots of expensive and time-consuming work.[X(]
The fast-and-not-terribly-expensive way to swap out the brakes is to put an entirely different front end on the bike. I'm looking for an FZ1 front end myself to do this...not so much because I want to swap the brakes, but because I want an externally-adjustable front end...but the brakes will be a good side benefit.
