engine clank
Old Oct 10, 2008 | 12:50 AM
  #21
Shadow's Avatar
Default RE: engine clank
Consider these -
Old Oct 10, 2008 | 01:02 AM
  #23
ebinz88cane's Avatar
ORIGINAL: Kasnooze50
how can you test to see if there bad? and does the have to come out of the bike to work on it?
Read the manual. They talk about inspection on the CCT & Chain ( could be stretched, but i doubt it). No way to inspect the alt chain without splitting the case (from what I know)
Like its been said, its a very common issue with these bikes. and there is A LOT of information concerning these issues on past posts.
Good luck. THe Manual will save your life. I personally bought a Haynes manual.. seems to make things a little more layman.
Old Oct 13, 2008 | 04:46 PM
  #24
Kasnooze50's Avatar
how do you adjust the balance shaft?
Old Oct 13, 2008 | 05:30 PM
  #25
Naga_Thai's Avatar
Suggest you look at the workshop manual as it is easy to see there..... page 10-4 ....
1990 Honda manual (page 10-9) states: "Adjust the backlash while the engine is cold. Loosen the pinch bolt and turn the shaft counterclockwise up to dead end and back off by one graduation. Apply a locking agent to the threads of the pinch bolt and tighten it securely."
Here islink to the manual http://members.iinet.net.au/~cbr/Hon...ice_Manual.pdf or https://cbrforum.com/m_123412/tm.htm
Old Oct 16, 2008 | 08:52 PM
  #26
Kasnooze50's Avatar
i checked into a timing chain that has a master link, but nobody know about them. Were did you guys get them?
Old Oct 16, 2008 | 10:04 PM
  #28
Shadow's Avatar
D I D and Takasago both make cam timing chains with master links.
It's been discussed before, about two months ago - check previous posts, mine and others.
Old Oct 16, 2008 | 11:22 PM
  #30
MarkR's Avatar
Are those training wheels de-linked
