Engine Balancer
Old Oct 30, 2007 | 06:26 PM
weekendrider's Avatar
Default Engine Balancer
How often should you adjust it. I did mine for the first time since i had the bike, 30000k i have doneand it went up a long way.
Old Oct 30, 2007 | 08:39 PM
malbojah's Avatar
Default RE: Engine Balancer
I try and do it every time I do a valve adjustment
Old Oct 31, 2007 | 05:14 AM
bluebeard's Avatar
I was told by the shop to not ever bother with it, so I left mine alone. I've just had my cases apart & decided to check the adjustment upon re assembly. I'm glad I did as it was out a long way. I think I'll check it more often. Thanks for the timely post!
Old Oct 31, 2007 | 02:29 PM
DRam's Avatar
Very Honorable Most Senior Member :)
General advice it to play with the balancer only when splitting the cases or rebuilding the engine. However with miles it can drop out of adjustment and need fiddling with. Mine got to the point that a few miles at highway speeds resulted in numb hands. A few minutes adjusting the balancer took care of that. Adjustment shouldn't be needed on a regular basis though.
Old Nov 1, 2007 | 11:32 AM
Noe's Avatar
Noe
Asfar as I remember, the Honda manual is saying you should adjust the balancer together with the big service
Old Jul 23, 2008 | 05:40 AM
boink1079's Avatar
Funny how the "old" posts get a bump! I adjusted my balancer for I think the first time in my Cane's life. I lost count after 20 revolutions....The vibration in the bars has gone and I will add this to my maintenance schedule. Thanks to all!
Old Jul 23, 2008 | 10:00 AM
tallenuf's Avatar
Hey boink, sounds like you adjusted your balancer with the engine off. I tried that and the thing just kept spinning around with no resistance. I inquired on the forum here about it and was instructed to try adjusting it with the engine running. With the engine on I only had to turn the shaft a little and could hear the result. Just turn it counter clockwise until it starts to whine and then back it off a little until the whine stops. Sweet!
Old Jul 24, 2008 | 07:29 AM
boink1079's Avatar
Hey Tallenuf,
Yep, I tried both. I did not reach a "stop end" although I could hear the motor "rattle" then go quiet. No "whine" to speak of. Maybe keep turning?????
Old Jul 24, 2008 | 10:07 AM
tallenuf's Avatar
Sounds to me you've got it perfect, no rattle and no whine!
Old Jul 26, 2008 | 05:25 AM
boink1079's Avatar
Tallenuf, I'm not so confident...I'm tuning carbs tomorrow and I'll have another go before I tune - so the engine is cold. I'll post back results....
