dumb question about fuel tap
My seat doesnt have the ring that denotes the position of the fuel tap...I ordered one and it has ON then OFF then RES...On being on top...is this correct? is there something wrong with my fuel tap then? because I always turn mine 1/4 turn from up and down to sideways and go...by that part it would show OFF...Mine runs when sideways and down...havent tried it up...
Yes, it is correct. Up should be on. To the right (horizontal) should be off. Down should be reserve.
Interesting. Ok, I went down and looked. Here is your problem.... Somebody put your knob back on wrong (i'm guessing). If you remove the screw from the center of the knob, you can slide the knob off and then put it back on wherever you want. (post for the knob is square) Easy way to fix it would be to take off the seat, turn the knob as far as it will turn to the LEFT. (This will be ON) Take off the knob. Put it back on with the arrow pointing to ON. Done deal. |
ok.....so then why does mine run when its to the right (off)? Ive been riding it like that from day one. Is there something broken or missing in there? I know the vacuum thing works fine.
thanks by the way. |
I went back down and took it apart again.
Apparently I was wrong, and you can't put the knob on wrong. One corner of the square post is rounded so you can only put it on in the right orientation. My bike is a 1995. I'm not sure if they changed it through the years. I doubt it, but who knows. Not sure why yours would run in the "off" (horizontal) position. Got me. |
Mine runs when off also, fwiw i wouldn't worry about it
The owner's manual says something like "turn the tap off for long term storage or maintenance purposes". At a guess i'd say the tap would stop gravity feed of fuel but the fuel pump sucks the fuel right through when she's running ?. |
I suppose the seal could be shot inside.
I know mine won't run in the off position. I found that out the first day I rode it to work. The clowns I work with decided it would be funny to shut off my fuel when I wasn't looking. I didn't get very far. You can imagine how upset I was. I just bought the dam bike. Luckily, I looked at the fuel switch first. :) |
Somebody put your knob back on wrong (i'm guessing) I have no idea why that would do that either , short of something not quite right inside the tap..? One corner of the square post is rounded so you can only put it on in the right orientation If you are really concerned about it mate .. I think perhaps a dis assembly is the go:rolleyes: , to check for a broken tap or dead seals ?:eek: |
Originally Posted by swisherred
(Post 772882)
my seat doesnt have the ring that denotes the position of the fuel tap...i ordered one and it has on then off then res...on being on top...is this correct? Is there something wrong with my fuel tap then? Because i always turn mine 1/4 turn from up and down to sideways and go...by that part it would show off...mine runs when sideways and down...havent tried it up...
down position is res. Pointing to rear of bike is off on (fuel) off res. |
I have no idea...I tried running it in all positions...still runs...guess it doesnt really matter unless my vacuum thing stops working someday...then it could be a problem...
lol
sh1t mate - most people on here are complaining that they cant get their bike to run. stop bragging that you cant get yours to not run :D:p:D |
