DCBS or LBS
Old Mar 9, 2021 | 11:57 AM
David Smedlund's Avatar
Angry DCBS or LBS
I haven't been able to get my Linked braking system figured out. I have tried and tried to get it bled correctly using the manual and a very detailed, with pics, run through on bleeding the brakes properly. I believe my secondary master cylinder is not bleeding correctly. I open the orifice hex screw and when I go to bleed the brakes, I have loosened the front nut towards the front brake cylinder on the proportion valve and no air or fluid comes out. The detailed bleeding instructions I have gotten says there should be fluid coming out of this area when the front brake lever is depressed and the nut is loosened. Meaning the brake fluid would run through the secondary master cylinder towards the proportion valve.
Anyone have instructions to unhook all this LBS and go with 2 separate systems (1 for the front brakes and 1 for the rear?)
Old Mar 9, 2021 | 12:12 PM
I believe it's been done, but not aware of the procedure or whats involved. Take a look at this thread. This guy just finished working on his linked system. It being fresh in his mind, he may have some good tips.
https://cbrforum.com/forum/general-t...roblem-161201/
alpiniste
How-To: Mechanical
Sep 24, 2017 07:50 AM
paultttt74
Feb 27, 2014 06:05 AM
ekelman
Mar 22, 2012 08:02 PM
iceman423
Jul 10, 2010 03:50 AM
pugzley1986
Apr 30, 2009 12:30 PM
