Daft question - bar end weights compatability?
Hi guys - forgive the probably stupid question, but are the bar end weights fairly universal across the range?
My '87 FH lost its bar ends before I bought her and there's a pair of '91 bar end weights on Ebay at the moment - will these bolt straight on?
Cheers,
Dave.
Cheers,
Dave.
on
They will - I just took inner bar weights from a 1990 and put them in an 87
handlebars and the external bar end weights fit perfect
There was little or no difference between the oem inner bar weight from the 87
and the one from the 1990 - the 90 was a 1.5cm's longer but still worked
So yeah 91 bar ends will work with 87 inner bar weights you may need the
91 bar end weight screws tho for length
Hope this helps.
Cheers, Steve
on
Yeah I went with a set of chrome ones from Ebay specific for honda bars too.
I can relate to Steves inner bar weight deal - I had one that had the outer neck
snapped off - was a real pain getting it out and like I said the inner from a 1990
worked just fine with some wd40 and a few belts of the persuader too
Cheers, Steve
